Mike M Posted March 6, 2008 Share Posted March 6, 2008 Been getting crap mileage since going BPU and I've tried a long run and being nice to it and noticed no difference. I reckon I've lost at least 60miles out the tank range. Anyway on idle I noticed that when I disconnect the vac ref hose to the BOV the revs pick up which I'm assuming is sucking in air making things slightly leaner. BUT does this mean its idling rich to start with? O2 sensor? The car has become very jerky when cold especially lifting off the throttle and does the slight misfire on idle thing all the time bump bump babump with the odd big one you can feel. New NGK sparks gapped to 0.9mm If I remember right for 1.0bar. I did have IK22's but my idle sounded and felt crap. Quote Link to comment Share on other sites More sharing options...
Daston Posted March 6, 2008 Share Posted March 6, 2008 get the o2 sensor out and get it in some lemon juice Quote Link to comment Share on other sites More sharing options...
Harllequin Posted March 6, 2008 Share Posted March 6, 2008 Lemon juice? Explain please Quote Link to comment Share on other sites More sharing options...
Homer Posted March 6, 2008 Share Posted March 6, 2008 If it's not misfiring when on full boost it points to an issue with the idle control IMO. However a first very simple check to make is to remove the coil pack connectors and check they are not brittle or have any missing insulators. Second check would be to do as Daston says and give the O2 sensor an overnight clean in lemon juice (be sure to clean it off before reinstalling), if it idles well afterwards it's time to order a new O2 sensor. Quote Link to comment Share on other sites More sharing options...
Harllequin Posted March 6, 2008 Share Posted March 6, 2008 So just what does the lomon juice do and how does it work. I've never heard of this one at all. Quote Link to comment Share on other sites More sharing options...
Homer Posted March 6, 2008 Share Posted March 6, 2008 So just what does the lomon juice do and how does it work. I've never heard of this one at all. After years of use (or misuse!) the O2 sensor can get clogged with carbon deposits, removing it and soaking the sensor in lemon juice (a mild acid) gently removes the deposits and can temporarily make them report correct readings to the ECU. In most cases this will show an improvement if the sensor is the cause of the problems. Cleaning is only a temporary measure, by this time the sensor is knackered and need renewing Quote Link to comment Share on other sites More sharing options...
Mike M Posted March 7, 2008 Author Share Posted March 7, 2008 Cheers guys, I dont suspect the ignition really new clips and coil packs fitted just over a year ago and the clips were good two months ago when I fitted the NGKs. However I do think its the original 93 O2 sensor in there since i'm the first uk owner. Might have been done in Japan but I cant read my service book and it was low mileage when it arrived. 60k miles. Anyone tried using lime juice? Trust me to have the other bottle LOL. Forgot to add, there's no misfiring on boost. Quote Link to comment Share on other sites More sharing options...
Harllequin Posted March 7, 2008 Share Posted March 7, 2008 aahh excellent. Thanks for the info I can just see the boss's face now. Picture the scene. I come in from the cold covered in oily black gunk. Hi there dear I'm just borrowing this to fix the car. (Darren runs from the kitchen) Quote Link to comment Share on other sites More sharing options...
tbourner Posted March 7, 2008 Share Posted March 7, 2008 I'm assuming you've tried resetting the ECU? Quote Link to comment Share on other sites More sharing options...
Nic Posted March 7, 2008 Share Posted March 7, 2008 However I do think its the original 93 O2 sensor in there since i'm the first uk owner. If it is the original O2 sensor then it will definitely need changing and should make a noticeable difference to mpg's and smoothness of the engine at lower rpms. If this wasn't in Tech, I could suggest someone to speak to about a new one Quote Link to comment Share on other sites More sharing options...
mr keef Posted March 7, 2008 Share Posted March 7, 2008 can you use tango? Quote Link to comment Share on other sites More sharing options...
Mike M Posted March 7, 2008 Author Share Posted March 7, 2008 I'm assuming you've tried resetting the ECU? Yep, no change. The only change I noticed was after ditching the fairly new IK22's to NGK's and it idled sweet as a nut then a few days later returned to its lumpy self. If it is the original O2 sensor then it will definitely need changing and should make a noticeable difference to mpg's and smoothness of the engine at lower rpms. If this wasn't in Tech, I could suggest someone to speak to about a new one Funnily enough I know a man who likes selling these too and he might very well hear from me soon. can you use tango? or coke, you know what that does to copper coins:) Quote Link to comment Share on other sites More sharing options...
tbourner Posted March 7, 2008 Share Posted March 7, 2008 or coke, you know what that does to copper coins:) Bang, and the dirt is gone! Quote Link to comment Share on other sites More sharing options...
Lebsteif Posted March 7, 2008 Share Posted March 7, 2008 Bang, and the dirt is gone! http://www.youtube.com/watch?v=PHGE7bO6Mg8 Quote Link to comment Share on other sites More sharing options...
Mike M Posted March 7, 2008 Author Share Posted March 7, 2008 http://www.youtube.com/watch?v=PHGE7bO6Mg8 Arrrggh he's fecking annoying. Quote Link to comment Share on other sites More sharing options...
