200SX Question
Harps
Nope - unless your running a really free flowing exhaust, and depending on how and iff your controlling your boost.
If your running standard boost, no problem, decat and forget.
If your running anything near a bar, you may hit boost cut on cold day or if you suddenly floor it, due to less resistance in the exhaust it can boost spike.
Even then you dont need a ring, just wind the boost down a touch.
Whats the spec of the sx? s13/14/a? full decat or just one?
Cheers guys, its for a friend of mine who's just fitted a boost gauge - its boosting up to 20psi. The problem may well be with the fitting of the gauge, but I'll see if I can get a bit more info. Though the boost cut is a very good suggestion, I'd not thought of that (hardly surprising! :) )
The 200 in question is a S14a
If hes hitting 20 psi:
1) its going to go bang uness hes done a lot of work to it
or
2) his boost gauge is lieing - boost cut is reliably on the nose of 1 bar (14psi) no way a standard car could make 20psi.
