Dave Posted March 6, 2008 Share Posted March 6, 2008 can you increase the revs at idle cause mine is on 450 -500 i think thats a bit low whats the correct idle revs ???? Quote Link to comment Share on other sites More sharing options...
dwayne Posted March 6, 2008 Share Posted March 6, 2008 i'd like to know the answer to that too as mine sometimes drops low enough to cut out. so far i've just been adjusting this Quote Link to comment Share on other sites More sharing options...
Nic Posted March 6, 2008 Share Posted March 6, 2008 That is quite low. I'd try resetting the ECU first, disconnect the battery for a few minutes, then take it for a drive, it may be a bit lumpy at first, but a few miles and the ECU will relearn the settings. Quote Link to comment Share on other sites More sharing options...
dwayne Posted March 6, 2008 Share Posted March 6, 2008 That is quite low. I'd try resetting the ECU first, disconnect the battery for a few minutes, then take it for a drive, it may be a bit lumpy at first, but a few miles and the ECU will relearn the settings. i tried that already mate Quote Link to comment Share on other sites More sharing options...
CarlT67 Posted March 6, 2008 Share Posted March 6, 2008 I believe that you cant adjust the idle as it is controlled via the idle control valve and the ECU. However it must be determined by an input to the ECU, unfortunately I don't know what that is, if I knew it may fix my car too. Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted March 7, 2008 Share Posted March 7, 2008 Same expiriences here. ECU has been reset several times when doing other stuff. After going full BPU for the second time (had a period with the 1st cat in) the problem seemed to be worse. It holds 500 rpm nicely but if I start the engine when its warm (0-60 minutes after a drive) it revs VERY uneven and usually dies on me untill I either turn on the AC (to lift rpm) or drive a few meters. Then all is well (if 500rpm idle is well). Cant figure. Can this also be o2 sensor? Quote Link to comment Share on other sites More sharing options...
Dave Posted March 7, 2008 Author Share Posted March 7, 2008 That is quite low. I'd try resetting the ECU first, disconnect the battery for a few minutes, then take it for a drive, it may be a bit lumpy at first, but a few miles and the ECU will relearn the settings. i tried that too sometimes its ok but if im in D waiting at a junction it feels as its going to cut out if i put it in N the revs increase a little Quote Link to comment Share on other sites More sharing options...
dwayne Posted March 8, 2008 Share Posted March 8, 2008 i sorted mine!!! (well temporarily) cleaned my 02 sensor, reset ecu and it cured it. probably wont last long but i've got a new one on the way Quote Link to comment Share on other sites More sharing options...
SupraTRD83 Posted May 11, 2009 Share Posted May 11, 2009 How did you clean you 02 sensor? Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 12, 2009 Share Posted May 12, 2009 The low idle is the symptom of a problem, not a problem in itself. Find and fix the actual problem and your idle will be sorted Check fuelling (i.e. the O2 sensor), it's probably too rich. MAF based cars may have an air leak in the intake system. -Ian Quote Link to comment Share on other sites More sharing options...
themodifiedkid Posted May 12, 2009 Share Posted May 12, 2009 Sorry to hijack this thread but my car when settled idles between 800 and 850 revs, is this too high? Cheers Quote Link to comment Share on other sites More sharing options...
Homer Posted May 12, 2009 Share Posted May 12, 2009 Sorry to hijack this thread but my car when settled idles between 800 and 850 revs, is this too high? Cheers For a completely stock car it's slightly higher than normal once fully up to temp, are there any other signs of issues? Most TT's idle around 650-800rpm, the NA seems to have a lightly higher idle at around 750-850rpm (at least on mine!) Quote Link to comment Share on other sites More sharing options...
Supranature Posted May 12, 2009 Share Posted May 12, 2009 Clean your IACV out with brake/carb cleaner. Sudden low revs points to this IMO Quote Link to comment Share on other sites More sharing options...
Supranature Posted May 12, 2009 Share Posted May 12, 2009 Dave (OP), on an NA it is facing you on the top of the left-hand cam cover. Best of luck getting the bottom screw out! Quote Link to comment Share on other sites More sharing options...
themodifiedkid Posted May 12, 2009 Share Posted May 12, 2009 For a completely stock car it's slightly higher than normal once fully up to temp, are there any other signs of issues? Most TT's idle around 650-800rpm, the NA seems to have a lightly higher idle at around 750-850rpm (at least on mine!) No signs of any other issues that I can see/hear/feel. Its an auto if this makes any sort of difference:blink: Quote Link to comment Share on other sites More sharing options...
SupraTRD83 Posted May 12, 2009 Share Posted May 12, 2009 It does my head in, coming back from the girlfriends tonight it cut out on me twice when stopping at traffic lights, only cured when I put the lever into N at a stand still Quote Link to comment Share on other sites More sharing options...
SupraTRD83 Posted May 12, 2009 Share Posted May 12, 2009 No signs of any other issues that I can see/hear/feel. Its an auto if this makes any sort of difference:blink: same Quote Link to comment Share on other sites More sharing options...
Supranature Posted May 12, 2009 Share Posted May 12, 2009 Oops, meani ICV, not IACV in earlier post. This refers to aTT, but you may get the drift,,,,,,,,,, http://www.mkivsupra.net/vbb/showthread.php?t=80413&highlight=icv Quote Link to comment Share on other sites More sharing options...
