Autobox sump
jamesmark
After getting this replaced at the sump plug was loose and thread was stipped, it is leaking again from the seal.
Place that fitted the new sump used sealent (black in colour) to seal it, now this has not worked is there a gasket for the sump? Any part number for it available?
Or what is the best way to seal it?
I'd have thought it would be a bead of RTV sealant on the mating flange when built in the factory. Check with someone who has access to the parts system though.
You can get small tubes of this stuff. Most bearing stockists stock it.
Big tube here http://www.tooled-up.com/Product.asp?PID=134871&RelType=2
This will last you years as long as you cap it off so it doesn't set. Hundreds of uses around the home & garage ;)
  • 3 years later...
Sorry to bump an old thread, but the search threw this up as the most relevant topic.
I've a leak from my auto-box sump, I was looking for a part number for the gasket but gather from Chris' post that it doesn't exist and some gasket seal should do the job. Does anyone know if there's a filter in the sump that I should be changing while I'm at it?
  • 2 weeks later...
I've got a problem :(
There was a gasket when the pan was taken off, it crumbled when it was removed. The garage used rtv and left it for a good while before putting it back on. It's pissing out, the mechanic said that there was a small ridge to locate the gasket on to and because of this rather than a totally flat surface the sealant won't work. Mine's a facelift auto if that makes any difference.
Would anyone be able to check the catalogue please to see if a gasket is listed? (autobox sump gasket)
there is a filter,worth replacing for the £30ish i think my last one was,
your mechanic talking rubbish.silcone rtv nice thick bead on a very well cleaned sump and spotless grease free mating surface on the box.as i said previosly in this thread left to skin over wont leak if done properly.ive done this many times and never had a leak
hth
For the benefit of future searches in case anyone else has a similar issue:
A few attempts to seal the sump with RTV failed, and even though a gasket is not listed there was definitely a cork gasket there when the sump pan was removed. It's possible that the gasket was fitted by a previous owner, however I bought my Supra 5 years ago with around 50k miles on it so I wouldn't have thought the sump would have been removed previously.
To solve the problem, my mechanic was able to get a roll of cork gasket from my local motor factors, placed the sump pan on it and drew round it, cut it out and then cut out the centre, and used a hole punch to make holes for the bolts. No more leak :)
