mr keef Posted March 5, 2008 Share Posted March 5, 2008 Hi all, just fitted a front mount intercooler,facelift indicators,and now its all back together the slip controll light on the dash constantly flashes off,when i press the button nothing happens still keeps flashing...any ideas?it was working fine before the work. cheers keef Quote Link to comment Share on other sites More sharing options...
Sean1933 Posted March 5, 2008 Share Posted March 5, 2008 Mine did this when i had a loose connection at the TRAC ECU in the passenger footwell...seems strange that it started after the above work though. Quote Link to comment Share on other sites More sharing options...
mr keef Posted March 5, 2008 Author Share Posted March 5, 2008 well got into the car today and its fine Quote Link to comment Share on other sites More sharing options...
charliesupra Posted September 23, 2024 Share Posted September 23, 2024 On 3/5/2008 at 7:02 AM, Sean1933 said: Mine did this when i had a loose connection at the TRAC ECU in the passenger footwell...seems strange that it started after the above work though. do you know the trac ecu part number by any chance? Quote Link to comment Share on other sites More sharing options...
tayr Posted September 24, 2024 Share Posted September 24, 2024 1 Quote Link to comment Share on other sites More sharing options...
charliesupra Posted September 24, 2024 Share Posted September 24, 2024 tayr, thank you for your time, mine is 96 6 speed tt ? or does it share with the same traction control ecu? Quote Link to comment Share on other sites More sharing options...
Homer Posted September 24, 2024 Share Posted September 24, 2024 No, that’s for a different model car. There are several ways to find the correct part number, the easiest is to go to: www.toyodiy.com , input your car details and find it directly. Alternatively you can state here your car details, exact model from the vin plate(not chassis number), market (UK, EU, US or JDM) and whether it’s facelift or not. 1 Quote Link to comment Share on other sites More sharing options...
charliesupra Posted September 25, 2024 Share Posted September 25, 2024 23 hours ago, Homer said: No, that’s for a different model car. There are several ways to find the correct part number, the easiest is to go to: www.toyodiy.com , input your car details and find it directly. Alternatively you can state here your car details, exact model from the vin plate(not chassis number), market (UK, EU, US or JDM) and whether it’s facelift or not. thank you boss, i will check it out, seems like sharing the same part, only throttle control ecu no traction ecu for my car. guessing the thottle ecu might be bad as it keep blinking flashing ( orange ), will try to buy one used see how it end up and keep you posted thank you ! Quote Link to comment Share on other sites More sharing options...
