Tee from China Posted March 5, 2008 Share Posted March 5, 2008 Noticed the other day that there is a damper mounted on the front of the turbo engine which apparently is only fitted to manual versions. Can anyone explain why only manuals have this and therefore if someone converts an auto to manual should this be fitted also? Quote Link to comment Share on other sites More sharing options...
Ian C Posted March 5, 2008 Share Posted March 5, 2008 I believe, oh fonty one, that it stops the belt jumping off in overrev situations by someone dropping into say 2nd instead of 4th by accident. -Ian Quote Link to comment Share on other sites More sharing options...
fri3ndly Posted March 5, 2008 Share Posted March 5, 2008 oh fonty one well said Quote Link to comment Share on other sites More sharing options...
Tee from China Posted March 6, 2008 Author Share Posted March 6, 2008 I believe, oh fonty one, that it stops the belt jumping off in overrev situations by someone dropping into say 2nd instead of 4th by accident. -Ian Thanks Ian I like it too:innocent:but you have only given half an answer! If that is the reason should it be fitted in going Auto to manual? Quote Link to comment Share on other sites More sharing options...
Soop Dogg Posted March 6, 2008 Share Posted March 6, 2008 Thanks Ian I like it too:innocent:but you have only given half an answer! If that is the reason should it be fitted in going Auto to manual? *tsk* Come on Ian - answer the fonty question properly! Quote Link to comment Share on other sites More sharing options...
Tee from China Posted March 7, 2008 Author Share Posted March 7, 2008 *tsk* Come on Ian - answer the fonty question properly! Quote Link to comment Share on other sites More sharing options...
Ian C Posted March 7, 2008 Share Posted March 7, 2008 Thanks Ian I like it too:innocent:but you have only given half an answer! If that is the reason should it be fitted in going Auto to manual? If it's a support system for a manual gearbox overrev situation then I would have thought I'd have given you enough info to make the decision yourself Either fit it, or make sure you don't overrev by fumbling a gearchange. Bit like ABS and airbags and a fuel cutoff system - don't have them if you don't want to, but make sure you don't crash Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted March 7, 2008 Share Posted March 7, 2008 If it's a support system for a manual gearbox overrev situation then I would have thought I'd have given you enough info to make the decision yourself Either fit it, or make sure you don't overrev by fumbling a gearchange. Bit like ABS and airbags and a fuel cutoff system - don't have them if you don't want to, but make sure you don't crash ^^^^^ If it's a support system for a manual gearbox overrev situation then I would have thought I'd have given you enough info to make the decision yourself Either fit it, or make sure you don't overrev by fumbling a gearchange. Bit like ABS and airbags and a fuel cutoff system - don't have them if you don't want to, but make sure you don't crash Quote Link to comment Share on other sites More sharing options...
Thorin Posted March 7, 2008 Share Posted March 7, 2008 I say fit it. Quote Link to comment Share on other sites More sharing options...
JODY T Posted March 7, 2008 Share Posted March 7, 2008 well said Quote Link to comment Share on other sites More sharing options...
ivan Posted March 7, 2008 Share Posted March 7, 2008 ^^^^^ If it's a support system for a manual gearbox overrev situation then I would have thought I'd have given you enough info to make the decision yourself Either fit it, or make sure you don't overrev by fumbling a gearchange. Bit like ABS and airbags and a fuel cutoff system - don't have them if you don't want to, but make sure you don't crash Spoilsport - make him work it out himself - he's good with fonts. Quote Link to comment Share on other sites More sharing options...
Willson Posted March 7, 2008 Share Posted March 7, 2008 http://img110.mytextgraphics.com/glittertextlive/2008/03/07/afe42684ce1d016d613cf58843737f32.gif Quote Link to comment Share on other sites More sharing options...
Blackie Posted March 7, 2008 Share Posted March 7, 2008 http://img110.mytextgraphics.com/glittertextlive/2008/03/07/afe42684ce1d016d613cf58843737f32.gif Glitter text, When normal text just isent gay enough Quote Link to comment Share on other sites More sharing options...
Tee from China Posted March 9, 2008 Author Share Posted March 9, 2008 Thanks to all for their 'valued' input - has really helped....not! Some real p*st*kers on here as soon as somebody does something different!! was going to do this in different fonts,colours and sizes but would be a real PITA:eyebrows: Quote Link to comment Share on other sites More sharing options...
