dannypunto Posted March 4, 2008 Share Posted March 4, 2008 just done a quick caliper swop from j spec to uk spec on the front and the wheels catch, anybody know what spacers i need and where to get them from? Quote Link to comment Share on other sites More sharing options...
hodge Posted March 4, 2008 Share Posted March 4, 2008 you must be still running on 16" wheels mate as the uk specs came with 17" wheels. I would personally invest in a larger diamiter wheel. I know this would be costly but worth it in the long run. good luck mate. Hope you get it sorted. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted March 4, 2008 Share Posted March 4, 2008 Get Project Kics, excellent quality Spacer for Jap cars http://www.neweraparts.com/ Quote Link to comment Share on other sites More sharing options...
dannypunto Posted March 4, 2008 Author Share Posted March 4, 2008 you must be still running on 16" wheels mate as the uk specs came with 17" wheels. I would personally invest in a larger diamiter wheel. I know this would be costly but worth it in the long run. good luck mate. Hope you get it sorted. i think u mis-understood, i have a j spec TT with 18" wheels on, i have uk spec brakes to install, tried put them on and they catch my wheels, this is why i need spacers? Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted March 4, 2008 Share Posted March 4, 2008 i think u mis-understood, i have a j spec TT with 18" wheels on, i have uk spec brakes to install, tried put them on and they catch my wheels, this is why i need spacers? A lot of 18" wheels won't clear UK Brakes, hence why people always ask before buying wheels. Quote Link to comment Share on other sites More sharing options...
dannypunto Posted March 4, 2008 Author Share Posted March 4, 2008 yeah, i already had the wheels on the car, it was a risk worth takin buying the brakes without defo knowing they will fit, but a risk i think worth takeing, just need some spacers and all will be good , any uk companys sell them? Quote Link to comment Share on other sites More sharing options...
Jellybean Posted March 4, 2008 Share Posted March 4, 2008 yeah, i already had the wheels on the car, it was a risk worth takin buying the brakes without defo knowing they will fit, but a risk i think worth takeing, just need some spacers and all will be good , any uk companys sell them? http://www.neweraparts.com/ Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 4, 2008 Share Posted March 4, 2008 There are no definite answers unless someone already has the same wheels on there car with UK brakes! a tip, if you want to find out what width of spacers you need, providing you know you wont need more than 15mm is to get yourself a bunch of washers to fit the studs, and keep putting them on until you can spin the week without it touching, check caliper clearance, you will need to clear them by about 3mm and then just take off the washers and measure the stack with a vernier or micrometer then you will know what width of spacer you need, or if you can't be bothered, buy a set of 3mm and a set of 5mm and see what it takes to clear. Quote Link to comment Share on other sites More sharing options...
dannypunto Posted March 4, 2008 Author Share Posted March 4, 2008 There are no definite answers unless someone already has the same wheels on there car with UK brakes! a tip, if you want to find out what width of spacers you need, providing you know you wont need more than 15mm is to get yourself a bunch of washers to fit the studs, and keep putting them on until you can spin the week without it touching, check caliper clearance, you will need to clear them by about 3mm and then just take off the washers and measure the stack with a vernier or micrometer then you will know what width of spacer you need, or if you can't be bothered, buy a set of 3mm and a set of 5mm and see what it takes to clear. why can it be more than 15mm? Quote Link to comment Share on other sites More sharing options...
garethr Posted March 4, 2008 Share Posted March 4, 2008 Get Project Kics, excellent quality Spacer for Jap cars http://www.neweraparts.com/From the pictures on Newera's site, they don't look hubcentric. If that's the case, then, personally, I wouldn't touch them with a bargepole. If you must use spacers, make sure that they are hubcentric and TUV approved. Quote Link to comment Share on other sites More sharing options...
Kranz Posted March 4, 2008 Share Posted March 4, 2008 why can it be more than 15mm? Probably because that's the amount of 'spare' thread on the wheel studs. To go any further will require extra long studs. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 4, 2008 Share Posted March 4, 2008 Probably because that's the amount of 'spare' thread on the wheel studs. To go any further will require extra long studs. Thanks! beat me to it. Quote Link to comment Share on other sites More sharing options...
dannypunto Posted March 4, 2008 Author Share Posted March 4, 2008 Probably because that's the amount of 'spare' thread on the wheel studs. To go any further will require extra long studs. can anybody say this for sure? , looking at the wheels and a rough gauge, i think i require 10mm spacers, but i will do the washer trick 1st, if 10mm is the case are we saying i dont need longer wheel pins Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 4, 2008 Share Posted March 4, 2008 Thanks! beat me to it. Oh and as for hub centric, if you only need 3 to 5mm then I'm pretty sure nobody does them, i am running 5mm on my fronts with no problem, not ideal but short of spending loads of money:search: Quote Link to comment Share on other sites More sharing options...
Jellybean Posted March 4, 2008 Share Posted March 4, 2008 From the pictures on Newera's site, they don't look hubcentric. If that's the case, then, personally, I wouldn't touch them with a bargepole. If you must use spacers, make sure that they are hubcentric and TUV approved. Spacers are hubcentric and can be up to 10mm - 30mm (increments of 5MM), these are bolt on Spacers so the safest option http://www.neweraparts.com/Default.aspx?tabid=54&txtSearch=spacers&CategoryID=1&List=0&Level=1&ProductID=83 Quote Link to comment Share on other sites More sharing options...
garethr Posted March 4, 2008 Share Posted March 4, 2008 Spacers are hubcentric and can be up to 10mm - 30mm (increments of 5MM), these are bolt on Spacers so the safest option http://www.neweraparts.com/Default.aspx?tabid=54&txtSearch=spacers&CategoryID=1&List=0&Level=1&ProductID=83 Fair enough, then. Couldn't see that in the pic. Oh and as for hub centric, if you only need 3 to 5mm then I'm pretty sure nobody does them, i am running 5mm on my fronts with no problemOK provided the wheel still sits on the spigot, I guess. Quote Link to comment Share on other sites More sharing options...
dannypunto Posted March 4, 2008 Author Share Posted March 4, 2008 its asking me on that site what size "Hubcentric Spacer" i need? whats that mean :S, anybody know what size? or is it different on all wheels? Quote Link to comment Share on other sites More sharing options...
Jellybean Posted March 4, 2008 Share Posted March 4, 2008 measure it with a ruler see what mm it is , I didn't get any for mine though becausevwe don't have enough room and plus they are bolt on so they will be safe On the website it gives u desk of what to measure if I correctly Quote Link to comment Share on other sites More sharing options...
dannypunto Posted March 4, 2008 Author Share Posted March 4, 2008 where am i measureing though? Quote Link to comment Share on other sites More sharing options...
dannypunto Posted March 12, 2008 Author Share Posted March 12, 2008 just done the washe trick and i need 20mm spacers, is this to big? will my wheel stick out to far? also anybody know answer to my question b4? Quote Link to comment Share on other sites More sharing options...
dannypunto Posted March 13, 2008 Author Share Posted March 13, 2008 anybody?? Quote Link to comment Share on other sites More sharing options...
kslb Posted March 13, 2008 Share Posted March 13, 2008 I wouldn't dream of putting 20mm spacers on I would get some wheels the right size and sell yours. They are not too pricey second hand and refurb costs are not huge so best to do it right. Just out of interest what 18" wheels do you have any pics? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 13, 2008 Share Posted March 13, 2008 Get rid of the wheels and buy some that fit. Quote Link to comment Share on other sites More sharing options...
dannypunto Posted March 13, 2008 Author Share Posted March 13, 2008 I wouldn't dream of putting 20mm spacers on I would get some wheels the right size and sell yours. They are not too pricey second hand and refurb costs are not huge so best to do it right. Just out of interest what 18" wheels do you have any pics? these ones, dont know what they are, they were on the car b4 it was imported, in nice condition too with good tyres so didnt really wanna sell, but if needs must! Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted March 13, 2008 Share Posted March 13, 2008 Get rid of the wheels and buy some that fit. Or go back to Jspec brakes until you can afford bigger wheels Quote Link to comment Share on other sites More sharing options...
