Quick query USB Hub driver help needed/
far
Can someone help me out please.
I bought a 'PocketSize' (thats the brand) USB hub the model is UH-174BP.
When I go put it in windows (2000) doesn't detect it as a USB device, when I click on the arrow and go to properties it says
'the drivers device is not installed (28) to install the drivers for this device click reinstall driver'
OK SO I do this and windows finds the driver but then says:
'An error occured during installation of device.The installation failed because driver was not specified for the device instance'
Now using my very small amount of hardware knowledge (and I stress SMALL lol) I take it I need to download a driver for this device from somewhere(it didnt come with a CD).Thing is windows 2000 usually detects usb devices so im not sure what to do or get a driver from.
Can someone help?
Might be a dumb suggestion but it caught me out and you aren't getting many replies.
Is the hub one which can be (optionally) powered ?
I had one of those and unless it WAS powered my 2000 box simply didn't recognise it for what it was.
I've also seen problems a couple of times with usb 2 devices being plugged into usb 1.0 connectors - should work but hey this is windows. XP seems much better than 2000 at sorting this stuff out.
PS. you do know that the pc connector is good?
Good luck
I tried to do a search on Microsoft site and it didnt give much info on it, Im pretty sure I got serivce pack 4 - I downloaded the latest stuff only about 1 month ago.
The hub is 1.2 (im only running a printer,RF keyboard and sometime SD card)
I take it if I have USB2.0 it will be backwards compatible?
Anyway it was only 4 squids so I might just buy another but I then have to wait for it to come through and what if that one doesnt work either? Boohoo :(
Any other suggestions?
btt
Anyone got anymore ideas before I through this fecker against the wall ?
If anyone has any ideas of what I could use this for or creative ideas on how I can destroy it I would like to here from you :D I was thinking about putting it throught the shredder at work but it migh not fit
Hey Far, you can call me chris now, known ya a while...
If its external and you are talking about a desktop as opposed to a laptop, then sling it, they're right cheap and you're better off with a version 2 usb anyway. Just get a PCI card and bung it in, should come with a driver disk and presto! all done!
