SupraGirlie Posted March 2, 2008 Share Posted March 2, 2008 Hey, Just went to start the car and it's turning over but not firing up. Only thing I've been messing around with today are the door cards whilst installing the new speakers. Haven't touched anything under the bonnet or anything to do with the battery. Ignition and warning lights come up as normal so I can't see how it could be the battery. Only thing i can think of is the fact that the plug that goes into the door card on the passenger side currently isn't plugged in. I doubt this would be the cause of the problem but you never know. Any help would be much appreciated. Cheers Quote Link to comment Share on other sites More sharing options...
Scott Posted March 2, 2008 Share Posted March 2, 2008 Pretty sure its nothing to do with the door cards or plugs being off but you never know. My drivers side is off at the moment and its not causing any problems. Immobiliser? Fuel pump? Scott =op Quote Link to comment Share on other sites More sharing options...
colsoop Posted March 2, 2008 Share Posted March 2, 2008 It may be the battery, It takes quite a bit of power to start a car. The battery will still show lights as they are only a small amount of power. It could also be a fuse thats blown Quote Link to comment Share on other sites More sharing options...
uk-rich Posted March 2, 2008 Share Posted March 2, 2008 my money is on the battery, give it some charge and try it later Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted March 2, 2008 Share Posted March 2, 2008 Did you have the stereo running while you were installing the speakers? If you're running an amp etc., its amazing how quickly it runs the battery down. Quote Link to comment Share on other sites More sharing options...
Supradoopa Posted March 2, 2008 Share Posted March 2, 2008 What about your starter motor, does it click when you try to start her up? Quote Link to comment Share on other sites More sharing options...
SupraGirlie Posted March 2, 2008 Author Share Posted March 2, 2008 I don't think it's anything to do with the door card either. Thought it was worth saying something about it though. I didn't have anything running whilst i was working on the car. Interior light was off, no radio (only to test the rear speakers when i got them in). How would i check the immob and fuel pump? Will check for blown fuses. Will also give the battery some charge and see how i get on. Too dark to do anything now though Thanks for the replies Quote Link to comment Share on other sites More sharing options...
SupraGirlie Posted March 2, 2008 Author Share Posted March 2, 2008 What about your starter motor, does it click when you try to start her up? Yeah it clicks and turns over fine. Just doesn't start Quote Link to comment Share on other sites More sharing options...
Scott Posted March 2, 2008 Share Posted March 2, 2008 If the fuel pump is working it will prime when you turn the key. If you turn the ignition on you should hear a droning sound, thats the fuel pump priming. Pretty sure if you hear that its not it though. As for the immobiliser i don't really know tbh. Scott =op Quote Link to comment Share on other sites More sharing options...
Dave Posted March 2, 2008 Share Posted March 2, 2008 have you got petrol in it cause if its turning over and not starting .mine will start on a half charged battery Quote Link to comment Share on other sites More sharing options...
Guest Garfy Posted March 2, 2008 Share Posted March 2, 2008 possibly a silly question this, but is it still in park? just thought that if you have been playing around with the stereo you may have taken it out of park to get better access, and I can't rememeber if it still turns over but wont start, or if it doesn't turn over when not in park. Quote Link to comment Share on other sites More sharing options...
Supradoopa Posted March 2, 2008 Share Posted March 2, 2008 Yeah it clicks and turns over fine. Just doesn't start Yep same problem I had, the starter motor kept on clicking, in the end I got it refurbed. I went down the whole route of getting a new battery etc I'm sure a tech guru will be along shortly Quote Link to comment Share on other sites More sharing options...
carl0s Posted March 2, 2008 Share Posted March 2, 2008 Yep same problem I had, the starter motor kept on clicking, in the end I got it refurbed. I went down the whole route of getting a new battery etc I'm sure a tech guru will be along shortly He said it's turning over fine. Unlikely to be the battery then I would think. Quote Link to comment Share on other sites More sharing options...
Scott Posted March 2, 2008 Share Posted March 2, 2008 She Scott =op Quote Link to comment Share on other sites More sharing options...
SupraGirlie Posted March 2, 2008 Author Share Posted March 2, 2008 Yep the car is still in park. Full tank of petrol too. Yeah I hear the droning noise of the fuel pump. Gonna go and give it another go shortly. Quote Link to comment Share on other sites More sharing options...
simbasupra Posted March 2, 2008 Share Posted March 2, 2008 This website might help you: http://www.diyfixit.co.uk/motor/ click on Fault Finding / Starting problems - engine then read through pages 2 and 3 might point you in the right direction. Quote Link to comment Share on other sites More sharing options...
carl0s Posted March 2, 2008 Share Posted March 2, 2008 She Scott =op Oops. I should've figured that out Quote Link to comment Share on other sites More sharing options...
gaz1 Posted March 2, 2008 Share Posted March 2, 2008 if you have been pulling electrical plugs before disconnecting the battery, then my moneys on a blown fuse Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted March 2, 2008 Share Posted March 2, 2008 Only stock fuse that can stop the engine starting if the car is cranking and the fuel pump is pumping is the EFI fuse. Other than that it should fire. Sounds very much if its turning over properly that the ignition is not happening. The immobiliser could do this of course and who knows what circuit thats been fed off. Quote Link to comment Share on other sites More sharing options...
SupraGirlie Posted March 3, 2008 Author Share Posted March 3, 2008 Just checked the fuses, EFI fuse is fine and doesn't look damaged at all. Re-connected the door card and car still won't start. Everything sounds healthy though. Tried resetting the battery last night but that didn't work either. Any other bright ideas? I'm stumped. Thanks for your help everyone. Quote Link to comment Share on other sites More sharing options...
Scott Posted March 3, 2008 Share Posted March 3, 2008 Just checked the fuses, EFI fuse is fine and doesn't look damaged at all. Re-connected the door card and car still won't start. Everything sounds healthy though. Tried resetting the battery last night but that didn't work either. Any other bright ideas? I'm stumped. Thanks for your help everyone. Next thing is to check you are getting a spark. You will need to take off the spark plug cover, remove the HT leads, take out a spark plug, put it onto the HT lead and have someone crank the car. If the spark plug sparks, thats not the problem. Just to be sure, wait until someone confirms this check. I've done it in the past but i don't know if its adviseable lol. Scott =op Quote Link to comment Share on other sites More sharing options...
SupraGirlie Posted March 3, 2008 Author Share Posted March 3, 2008 I wouldn't mind doing this on a turbo, but on an NA.... :S Thanks for the suggestion though Quote Link to comment Share on other sites More sharing options...
Guest Artermis Posted March 3, 2008 Share Posted March 3, 2008 you say its turning over, does it sound likes turning over really quickly and easily compared to how it usually sounds? also if you've been trying and trying the plugs could get wet, if your going to have em out maybe worth cleaning them up Quote Link to comment Share on other sites More sharing options...
SupraGirlie Posted March 3, 2008 Author Share Posted March 3, 2008 I'm not prepared to take the plugs out unfortunately. Whilst I'm sure it's a very straightforward job it's just not something I want to try without supervision lol. Yeah it does sound as though it's turning over quicker than usual... Quote Link to comment Share on other sites More sharing options...
Scott Posted March 3, 2008 Share Posted March 3, 2008 Starter motor belt snapped? Scott =op Quote Link to comment Share on other sites More sharing options...
