SUPRA FLY Posted January 25, 2005 Share Posted January 25, 2005 Need views from the technical Gurus amongst us Just noticed over the last week my hand break light comes on when I break (foot break) hard Any ideas?? Quote Link to comment Share on other sites More sharing options...
Nic Posted January 25, 2005 Share Posted January 25, 2005 The most common cause for this is low brake fluid, make sure it is completely full. Quote Link to comment Share on other sites More sharing options...
SUPRA FLY Posted January 25, 2005 Author Share Posted January 25, 2005 Cheers mate.....will check that Quote Link to comment Share on other sites More sharing options...
mawby Posted January 25, 2005 Share Posted January 25, 2005 If it is low then it could be an indication that the pads are low. Worth checking before you fill it up only to have it overflowing when you put new pads in. Quote Link to comment Share on other sites More sharing options...
Duffers Posted January 25, 2005 Share Posted January 25, 2005 Mine has also started displaying the triangle of death along with the handbrake light when I brake quite hard. It then clears when I accelerate a little. I'll check my levels later on and see what the score is. Do you get the triangle of death too Supra Fly? Or just the handbrake light? Let me know what you found too Supra Fly! Lets hope we can sort it ! Paul Quote Link to comment Share on other sites More sharing options...
mawby Posted January 25, 2005 Share Posted January 25, 2005 The triangle comes on with all other warning lights, so you will always get the triangle and the hand brake light on together. Quote Link to comment Share on other sites More sharing options...
SUPRA FLY Posted January 25, 2005 Author Share Posted January 25, 2005 Mine has also started displaying the triangle of death along with the handbrake light when I brake quite hard. It then clears when I accelerate a little. I'll check my levels later on and see what the score is. Do you get the triangle of death too Supra Fly? Or just the handbrake light? Let me know what you found too Supra Fly! Lets hope we can sort it ! Paul Yes I get the triangle light too at the same time. Will check it all tonight and let you know what I find. Hopefully that its all in which case we can sort it...... Quote Link to comment Share on other sites More sharing options...
Scarface GTti Posted January 25, 2005 Share Posted January 25, 2005 I was going to post this up today as i too have this problem. But my fluids are fine, so i`m guessing that there is a switch on the handbrake? that can be adjusted. Only problem is it isn`t obvious in the near dark how to get the panel off from around the handbrake? Quote Link to comment Share on other sites More sharing options...
SimonB Posted January 25, 2005 Share Posted January 25, 2005 I'd check your brake fluid level again - even when it's just about at max you seem to get this as the fluid sloshes around and triggers the warning. I should top it right up anyway. Quote Link to comment Share on other sites More sharing options...
mawby Posted January 25, 2005 Share Posted January 25, 2005 I'd check your brake fluid level again - even when it's just about at max you seem to get this as the fluid sloshes around and triggers the warning. I should top it right up anyway.Although to re-itterate make sure the low fluid isn't because your pads are getting low. Quote Link to comment Share on other sites More sharing options...
TRD3000GT Posted January 25, 2005 Share Posted January 25, 2005 Def low brake fluid. Just get a small top up! ;-) Cant beleive u did not ask me . I feel offended Quote Link to comment Share on other sites More sharing options...
SUPRA FLY Posted January 26, 2005 Author Share Posted January 26, 2005 Checked my brake fluid last night and it is quite low....closer to the min marker than the max marker so that appears to be the problem. I didn't have time to check the brake pads as well but will do soon. Quote Link to comment Share on other sites More sharing options...
mr_maj Posted March 17, 2005 Share Posted March 17, 2005 guys i take it that it was just brake fluid being low?? Im getting same problem on my supra! Quote Link to comment Share on other sites More sharing options...
SUPRA FLY Posted March 17, 2005 Author Share Posted March 17, 2005 Yep that was the problem with mine. Was a bit low...topped it up and it was fine. Quote Link to comment Share on other sites More sharing options...
mr_maj Posted March 17, 2005 Share Posted March 17, 2005 arite, where'd u get the fluid from and which brand/type? cheers. Quote Link to comment Share on other sites More sharing options...
