Hand Break Light
SUPRA FLY
Mine has also started displaying the triangle of death along with the handbrake light when I brake quite hard. It then clears when I accelerate a little. I'll check my levels later on and see what the score is.
Do you get the triangle of death too Supra Fly? Or just the handbrake light?
Let me know what you found too Supra Fly!
Lets hope we can sort it !
Paul
:thumbs:
Paul
Yes I get the triangle light too at the same time. Will check it all tonight and let you know what I find. Hopefully that its all in which case we can sort it...... :lalala:
I'd check your brake fluid level again - even when it's just about at max you seem to get this as the fluid sloshes around and triggers the warning. I should top it right up anyway.
Although to re-itterate make sure the low fluid isn't because your pads are getting low.
  • 1 month later...
