SUPRASUZUKI Posted March 1, 2008 Share Posted March 1, 2008 If the cat's impose back pressure on the turbos, so limiting boost and a restrictor ring does the same (albeit to a different degree), would a baffle in the tailpipe do the same? Could this give a dual benefit of lower noise (for track days) and controlled boost? Link to comment Share on other sites More sharing options...
Dazzi Posted March 1, 2008 Share Posted March 1, 2008 I've heard that a baffle can rob you of 30hp on a BPU Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 1, 2008 Share Posted March 1, 2008 It will quieten the exhaust, but will rob you of power to i lost 50BHP to a simple bung of 2.5" dia and about 6" long, and that was in a 3.5" exhaust. Link to comment Share on other sites More sharing options...
SUPRASUZUKI Posted March 1, 2008 Author Share Posted March 1, 2008 I've heard that a baffle can rob you of 30hp on a BPU Better to lose 30bhp than to miss out on track time though. Link to comment Share on other sites More sharing options...
SUPRASUZUKI Posted March 2, 2008 Author Share Posted March 2, 2008 It will quieten the exhaust, but will rob you of power to i lost 50BHP to a simple bung of 2.5" dia and about 6" long, and that was in a 3.5" exhaust. Was that with a restrictor ring and baffle? I'll have to accept a drop in power, but was really wondering if a baffle could do the same job as the restrictor ring. Link to comment Share on other sites More sharing options...
JohnnyW Posted March 2, 2008 Share Posted March 2, 2008 It's an interesting question mate, I'll be very interested in the answer. Could be a good way of doing db limited track days without loosing too much power. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 2, 2008 Share Posted March 2, 2008 Was that with a restrictor ring and baffle? I'll have to accept a drop in power, but was really wondering if a baffle could do the same job as the restrictor ring. Yes both! but i only removed the baffle to regain the 50BHP. Link to comment Share on other sites More sharing options...
