CD rom not working
supra steveo
Let's work backwards. When you say it's not working what exactly do you mean?
Does it whirr and spin away?
Does the read light come on?
Taking a guess I'm wondering if you have put a disc in and it hasn't started automatically.
Things I would try/consider:
1. Have you had the drive out/case open? If you have make sure the cables are seated properly, a pin could be bent, etc. The drive can be detected even with these problems, but won't read disks.
2. Does it read other disks OK?
3. Can you read the BF2 disk in another machine?
Quite often when a CD/DVD player is on its last legs it can start to get funny about playing disks.
New drive = £20 approx (unless you have a $ony or similar who love to make custom front bezels so theirs are silly money to replace)
Was the old drive doing the same thing?
Did fitting a new drive solve the issue?
If you're in a very dusty environment you may find that the lens is getting dirty and causing the poor read performance.
You can get cleaning solutions, but these are generally bad as they can knock the lens out of alignment.
Have you had a chance to try the things I suggested?
doh cant find my lense cleaner CD :( but when i took the side off i seen that the CPU fan was stuck in place :shock so gave it a hoover out but the DVD rom still doesnt work, and because germany closes down on sunday i wont be able to buy one today so i will have to wait till tomorrow till germany opens again (one down side to living in germany )
^^^ probably a good thing you couldn't find the CD cleaning kit! ^^^
By the sounds of it you are in a very dusty environment - if there's enough dust to stop the CPU fan, there's also enough dust to coat the CD/DVD lens.
happy to be corrected, but I have never had to install a driver for a CD/DVD drive so I don't think this could be the problem.
  • 2 weeks later...
