NA Clutch?
probrox
Looks like I need to replace my clutch as it's started slipping in all gears now. Can anyone tell me 1) Which clutch to go for, where from and rough cost, and 2) somewhere in the Ipswich or Colchester area to get it fitted (and price). Thanks
my lad took his to mr clutch in colchester, i think it was 250 fitted
ahhh just looked it up it could be chelmsford as we were working at harwich at the time:search:
Thats fine, I'm at college in Chelmsford every Thursday. Do you know if that included associated bearings as well? And is the flywheel ok to be skimmed or should i renew?
well to be honest they will probably tell you the flywheel will need replacing as there a bit quick fit like:d my lads is fine and its been on trackdays since;)
i just had mine done from nationwide clutch (yellow pages)
480 for a stock replacement they did it in one day! N/a 5speed manual
they said its the worse one they have removed more fell out than was connected oops not like i tryed a burn out for the first time :D
Normally Nick (Import Pimp) should be your best shot, if you can wait some time. Installing clutch and flywheel + gasket change on gearbox costed me around 200 pounds - it was perfect work of famous Mr. Wilson ;) Clutch, flywheel, master and slave cylinder got to around 420 pounds?
