Which headlight bulbs for JSpec and UK Spec?
Pete
Information kindly from Nic:
The correct bulbs for the J-spec plastic headlights (early and late model) are:
Low = 9006J
High = 9005J
The J variant of the bulbs are a different fit to the standard 9006/HB4 and 9005/HB3 bulbs. The 9005/HB3 bulbs will fit in place of the 9005J, but the 9006/HB4 bulb will not fit in the low beam (the diameter of the body of the bulb is too big). As an alternative you can use a 9005/HB3 bulbs in the low beam as well (note you will need to trim a rib on the connection with the harness so that they will fit, very easy to do), ie
Low = 9005HB3
High = 9005/HB3
Here are pics of each bulb to illustrate the differences, note the difference in the diameter of the 9006J (20mm) and 9006/HB4 (22mm) body; this is what causes the fitment problems.
Note: the UK spec glass headlights do not have this problem, they are designed to fit Low 9006/HB4 and High 9005/HB3
Edited by Pete
Fix images (see edit history)
  • 3 weeks later...
  • 4 weeks later...
  Jim_1979 said:
So for Jspec... 9005 in low and high beam.
Anymore info as to what part you actually trim? any pics?
It's a small rib inside the plug where the bulb connects to the wiring loom, it'll be obvious when you try to connect the bulb and loom.
  • 9 months later...
  • 10 months later...
  clodola said:
Why do people have to be such smart arses,
The Low = 9006J; High = 9005J for JSpec are not available in EU as far as I know
I just bough the HB4 Osram Cool Blue Bulbs, have not tried to fit them yet
Are you refering to me?
Btw, I think you'll need 2 sets of HB3 if yours is a J-spec
http://www.autobulbsdirect.co.uk/hb3-9005-bulbs/
Edited by Lbm (see edit history)
Correct
ray007 for reasons explained on first post, use 9005/HB3 in both the high and low beams, these should be available from any general motor parts shop, eg. Halfords
  • 2 weeks later...
What about US spec facelift headlights? I think my local dealer bought J-spec for my supra after i wanted to replace one headlight after some stonechip damage. I live in sweden, and there need US spec facelift headlights.
Could someone maybe post the toyota ordernr for this item?
  • 3 weeks later...
  MoeBlunt said:
anyone know what size the fog light bulbs are by any chance?
They are H3, I just ordered some blue ones to match my HID's, does anyone know what the size of the small driving,parking lights are?, I'd like those in blue as well.
  • 1 year later...
Sorry for the thread revival here, but I am trying to find a set of HID fog light bulbs to fit my Jspec headlights..
Anyone know what bulb the foglight is on Jspec, or where to get a HID kit for it?
the JSpec lights have HB3 for headlight and HB3 for dipped beam, and H3 for fog lights. i have the email address for the supplier for the groupbuy on here, he sells all the kits for 50gbp posted and a 1yr warrenty on all parts full replacement :)
  • 11 months later...
Low = 9006J
High = 9005J
Low = 9005HB3
High = 9005/HB3
http://img356.imageshack.us/img356/3983/90059005jub0.jpg
http://img297.imageshack.us/img297/3517/90069006jkg6.jpg
Thank you
Thanks so much for this. I just need to know where to buy the 2006J spec. I bought HB3 9005 and trimmed down and that fits fine.
  • 8 months later...
  WaLKeRR said:
So are people snipping the bulb rib or the harness its self rib, because i can see inside there is 2 nubbins where as the old bulb only had one hence why it needs snipping some off but which side bulb or harnes?
The bulb not wiring loom. I'm doing this this weekend.
  • 1 month later...
Guest suprabad82
are the UK spec and the N/A spefc headlights assemblies the same? and also if i went from a jspec to a UK spec assembly would it just be plug and play or would i have to do some mods?
