error code 24 and 31
kieren1234
Its for an na-t 1994 manual jspec.
I know 31 is the map sensor signal and i now think i have sorted the 24 which was the air intake temp sensor.
Whaere is the map sensor on na??
And could it be that when the e-manage is installed, you cut the map sensor wire at the ecu and have two wires from the e-manage, 1 going to each end.
Could my error 24 (intake temp sensor fault) cause my error 31 and cause the car to run rich because if the car cannot detect the intake tempretaures then im assuming it will just run rich.
Could this be correcxt as the car getting mapped Sunday but cant unless this is sorted.......
Really need your help guys:search::search:
