Guest daz 6576 Posted February 27, 2008 Share Posted February 27, 2008 need to know which hose goes were on my turbo install the turbo is a hks t04r the boost controller is a greddy profec b 2 there is no nipple on the turbo for the boost pipe to come from the solenoid how do i connect this all up Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted February 27, 2008 Share Posted February 27, 2008 Drill and tap a hole in the compressor housing of the turbo and fit a nipple for the pipe from to BC. Quote Link to comment Share on other sites More sharing options...
Homer Posted February 27, 2008 Share Posted February 27, 2008 As Kieren says, you'll need to drill and tap a hole on the compressor housing Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted February 27, 2008 Share Posted February 27, 2008 As Kieren says, you'll need to drill and tap a hole on the compressor housing Really dont think you should be doing this Daz as you really don't seem to know much about what you are doing. You can obviously learn along the way but at least get some research done!. Quote Link to comment Share on other sites More sharing options...
Guest daz 6576 Posted February 27, 2008 Share Posted February 27, 2008 ye but should i be doing this though this has been used on another car before and they havent had to do this, or do the boost hoses connect up to it differently Quote Link to comment Share on other sites More sharing options...
Homer Posted February 27, 2008 Share Posted February 27, 2008 They could have used a feed from further down the line (such as the IC pipe), but it really should be mounted as close as possible to point where the air is leaving the compressor blades, hence why pretty much every turbo has the mounting on the compressor Quote Link to comment Share on other sites More sharing options...
