2 questions to ask!
Guest SupraKingNI
Guest SupraKingNI
Just got myself a supra and had work done to it. it was an import so had it's been districted!
1. since its been districted whats the top speed it will now do?
2. how do i know what offset i need for the alloys?
Top speed will be when it runs out of puff, appx 180mph ish if the road is long enough. (pending if you have a TT that is)
Alloys should be close to +50 as possible, and also depends on if you have the larger brakes and also depends on the design of the wheel, best to buy wheels from someone that actually knows about Supra's and not just your local halfrauds.
Private Road i beleive :)
Indeed :D
The limit on my car I beleive was 6850rpm, so you'd need over 6920rpm limit to reach 200mph on a manual with around 550bhp.
That and a VERY long track with cold weather and a nice down hill bit towards the end :D
Edit - I don't think mine would have made 200mph even with a raised rev limit, it had no more to give when it hit the limiter.
