GUMBALL3000 Posted February 27, 2008 Share Posted February 27, 2008 Hey guy's.. I'm considering a project on my pre-facelift rear lights, which invloves replacing all the rear lenses with clear reversing lenses, and lighting with the appropriate coloured bulbs. So on the lookout for any clear reversing lenses if anyone knows of any available to buy, or very cheap complete units I can remove the lenses from. Any thoughts or advice appreciated.. Has this been done before?? Thanks!! Link to comment Share on other sites More sharing options...
jamesmark Posted February 27, 2008 Share Posted February 27, 2008 What have you got just now? As it is not as simple as just buying any clear lenses. You will require 4 x UK reversing lights and 2 x J-spec reversing lights. Link to comment Share on other sites More sharing options...
Lukeyboy2k Posted February 27, 2008 Share Posted February 27, 2008 I believe it has been done a few times before, some with better results than others. Assuming you already have a set of J-spec pre-facelift rears (on your car), you will need : 1) another identical set to change the reverse lenses with the indicators. 2) two sets of UK spec rears to replace the two red lenses. J-specs rears are easy to come by (£30 for full lights), occasionally the clear lenses become available on their own. Uk specs command a higher premium due to scarcity. The bulbs used to replace your existing plain ones will make all the difference IMO. I've seen it done with red and amber bulbs, which I think looks rubbish. Chrome bulbs that flash amber are easily available for the indicators, but I've yet to come across chrome bulbs that are red when illuminated (I haven't looked particularly hard TBH, I guess you could make your own). If you change each lens you are effectively removing the rear reflector (which I presume is an MOT requirement, perhaps you could stick on some red reflectors for the test). There are guides on here detailing exactly how to carry out the whole operation. Good luck. Link to comment Share on other sites More sharing options...
GUMBALL3000 Posted February 27, 2008 Author Share Posted February 27, 2008 jamesmark said: What have you got just now? As it is not as simple as just buying any clear lenses. You will require 4 x UK reversing lights and 2 x J-spec reversing lights. Oh.. Didn't know that.. Why is that?.. Sorry if it's a dumb question.. I currently have standard UK pre-facelift rears fitted. Thanks for your reply!! Link to comment Share on other sites More sharing options...
jamesmark Posted February 27, 2008 Share Posted February 27, 2008 GUMBALL3000 said: Oh.. Didn't know that.. Why is that?.. Sorry if it's a dumb question.. I currently have standard UK pre-facelift rears fitted. Thanks for your reply!! The the 2 centre lenses are a larger size. Link to comment Share on other sites More sharing options...
GUMBALL3000 Posted February 27, 2008 Author Share Posted February 27, 2008 Lukeyboy2k said: I believe it has been done a few times before, some with better results than others. Assuming you already have a set of J-spec pre-facelift rears (on your car), you will need : 1) another identical set to change the reverse lenses with the indicators. 2) two sets of UK spec rears to replace the two red lenses. J-specs rears are easy to come by (£30 for full lights), occasionally the clear lenses become available on their own. Uk specs command a higher premium due to scarcity. The bulbs used to replace your existing plain ones will make all the difference IMO. I've seen it done with red and amber bulbs, which I think looks rubbish. Chrome bulbs that flash amber are easily available for the indicators, but I've yet to come across chrome bulbs that are red when illuminated (I haven't looked particularly hard TBH, I guess you could make your own). If you change each lens you are effectively removing the rear reflector (which I presume is an MOT requirement, perhaps you could stick on some red reflectors for the test). There are guides on here detailing exactly how to carry out the whole operation. Good luck. Oh.. I see now. I have UK rears fitted, so will have to do the vice-versa, I presume. I have some chrome effect tail/stop/fog bulbs that illuminate red.. They are now readily available to buy. I have seperate rear reflectors fitted to the car. Are there any pics on here of this conversion? Thanks!! Link to comment Share on other sites More sharing options...
jamesmark Posted February 27, 2008 Share Posted February 27, 2008 Here is a step by step guide http://www.mkivsupra.net/vbb/showthread.php?t=35632 Use the search button to search for pictures, we can't do all the searching for you. Link to comment Share on other sites More sharing options...
Lukeyboy2k Posted February 27, 2008 Share Posted February 27, 2008 I'm feeling generous: http://www.mkivsupra.net/vbb/showpost.php?p=505561&postcount=5 Although I think I still prefer the reds to be there (if J-spec layout). Link to comment Share on other sites More sharing options...
bolarbag Posted February 27, 2008 Share Posted February 27, 2008 Oh god that looks hideous!! Love the car and blingy wheels though...yeah keep the red Link to comment Share on other sites More sharing options...
tooquicktostop Posted February 27, 2008 Share Posted February 27, 2008 I think the LED conversion (Heckler) would be much nicer looking than the clear look Link to comment Share on other sites More sharing options...
GUMBALL3000 Posted February 27, 2008 Author Share Posted February 27, 2008 Thanks guy's!! Mmmm.. Not too sure about that now. Maybe jap spec with clear indicator conversion, with the 2 reds in the middle will look better??.. I've seen pics of this conversion, and think it looks ok. Link to comment Share on other sites More sharing options...
GUMBALL3000 Posted February 27, 2008 Author Share Posted February 27, 2008 tooquicktostop said: I think the LED conversion (Heckler) would be much nicer looking than the clear look Yes, that is another option I am considering, and does look very good.. I like the Top Secret version, but on pre-facelift. Link to comment Share on other sites More sharing options...
Lukeyboy2k Posted February 27, 2008 Share Posted February 27, 2008 tooquicktostop said: I think the LED conversion (Heckler) would be much nicer looking than the clear look If I had standard lights it would definitely be something I'd look into - I might give it a go myself one day. GUMBALL3000 said: Thanks guy's!! Mmmm.. Not too sure about that now. Maybe jap spec with clear indicator conversion, with the 2 reds in the middle will look better??.. I've seen pics of this conversion, and think it looks ok. A nice, easy, cheap compromise I think. http://www.mkivsupra.net/vbb/vbpicgallery.php?do=big&p=9304 Link to comment Share on other sites More sharing options...
Nic Posted February 27, 2008 Share Posted February 27, 2008 Dude use to have all clear rear lenses on his car if I remember correctly. Link to comment Share on other sites More sharing options...
