Computer upgrade
TLicense
All,
I'm thinking it may be time to upgrade my pc.
My current spec is:-
AMD 700 athlon
256MB ram (not sure what type - is there an easy way to find out? It's about 4 years old.)
Nvidea geforce 4600ti 128mb graphics card
15GB HD
Soundblaster live soundcard.
I'm also using a wireless network adsl net connection.
So basically I'm looking for a motherboard/cpu/ram package that is going to last me another 3/4 years.
Ideally I'd like about 1GB of ram, minimum of 521Mb, 80GB hdd, >2GHz processor and a motherboard to match. I'm happy to use my existing sound and graphics cards
What would you guys recommend and where would you suggest the bargains are to be had? A friend of mine swears by ebuyer, but I've always gone Dabs in the past.
Suggestions please...
Tony
Definitely Ebuyer, they are cheaper than Dabs by a fair bit. Also Dabs are a nightmare if anything doesn't work and needs returning. A friend of mine at work had all sorts of trouble getting a return code out of them - in the end he pretended to be a business customer wanting loads of PCs. They mysteriously replied to his email immediately then!
Can anyone recommend a particular model of cpu and mother board? I have no idea which would be better than the other?
Cheers
i prefer amd as they used to be better performance for the money. dont know what its like now. not upgraded mine in ages as it does everything i need it to do. they move on so fast these days.
if you get a top spec comp and use your old graphics and sound would u not be holding it back. for what a ghrapics card and good sound card cost.
when i upgrade ghraphics again i will go for dual monitor output and 256megs onboard.
just look at some highend comps and see what specs they running.
Cheers guys,
I probably do some gaming, but use the machine for CAD hence the high RAM requirements. The more I can get the better. (Some files we do at work are often >2Gb - but I don't intend to be doing anything that large at home)
The graphics card I've got should be man enough for what I want it for, and I'm really not bothered about sounds at all.
I've been looking at the AMD xp range. I can get a 3200 for about £100 which will be a massive improvement over my current set-up.
With regards to RAM I take it DDR is the doggies?
I can get a 80Gb HDD for £35 plus delivery, which will do me nicely, especially as I've got 60GB of i-pod if things start to get a bit tight, let alone the 15GB that's in there to start with.
That reminds me, I'll have to use a dual boot system with Win2K on the 15GB drive and then XPpro on the 80GB. This shouldn't be a problem should it?
Thanks again chaps,
Tony
