Winter project almost finished.
b_have
Hyphahose is Poole.Can't remember the name but its quite flexible and smooth internally.
Nice, will have to see if i can get it online somwere :search:
how do you find the plenum, from a lag point of view
I'#d like to know this too. Where did you get it from and is it made by KU, if not then who?
Not sure tbh Paul, Spool is still good, but I changed cams at the same time, so hard to tell what did what.
I've been told that a Q45 (85mm) Throttlebody helps with spool and flows more top end. I have one here waiting to fit but not sure I need to go much further.
It came from KU enginnering, its a copy of the mega expensive Jun. Huge job to fit, had to move the fusebox/battery/ps res and some rewiring of the loom. It also needed some blueprinting and new throttlecable mount welding on.
Has there been any tests done on this intake manifold and did you test the intake mani for leaks before install?
I'm quite interested in these, do these mate up to the oem type Q45 throttlebodys?
Checked with endscope internally, (very nice casting) also checked machined areas which were good. The runners are cast integrally to the plenum with internal velocity stacks. I believe its an exact copy of the Jun.
