SilverSoop Posted February 23, 2008 Share Posted February 23, 2008 Hi all, yep ive finally got her back yesterday thankgod and you wont believe this, but the noise is STILL there. The guys at gearlink have tried their hardest to fix the gearbox and found two faulty gears which they have now replaced. So He came to the conclusion that it must be the gearbox oil. This got me thinking, because my box is a 6spd tt Getrag box, i thought that it should use only V160 gearbox oil but instead, they filled it with 10w 40 which they believe is better oil because the viscosity inst as low and would last longer in lubricating the gearbox. So the question is, what gearbox oil does everyone use and do you think that would be causing the noise?? Because now, i can hardly hear the noise when shes cold but when she warm, i can hear it clearly like i could before. The guy has worked on gearboxes for 15 years plus and hes stumped! Link to comment Share on other sites More sharing options...
johnd-mkiv Posted February 23, 2008 Share Posted February 23, 2008 I have just bought some v160 from wifbitz, I have read that they should only be run on it, not really worth the chance I guess. Link to comment Share on other sites More sharing options...
uk-rich Posted February 23, 2008 Share Posted February 23, 2008 paul wiffin can still get the proper stuff, i had some of him the other day you say 10w 40, that sounds like a motor oil spec:blink: Link to comment Share on other sites More sharing options...
supra matt Posted February 23, 2008 Share Posted February 23, 2008 They filled it with 10w 40 what engine oil!!!!!!!!!!! if i were you i would not drive the car to hard or far as think you might do some damage to the box , I would stick with stock toyota oil mate cant go wrong then . Link to comment Share on other sites More sharing options...
Supra-Brett Posted February 23, 2008 Share Posted February 23, 2008 The reason you cant hear the noise when its cold is because of the higher viscosity. Ive heard stories of rouge traders doing things like that in the past. Putting in mega thick oil to cover up problems/clanks. If there is still a clanking noise, there must still be an issue, as they arnt meant to make noises. simple as that. Not sure what the cause could be though. Hope you get it fixed. Link to comment Share on other sites More sharing options...
miko_supra Posted February 23, 2008 Share Posted February 23, 2008 hmmm 10w40 doesnt sound right. i use 75w90 in my gearbox Link to comment Share on other sites More sharing options...
Terminator Posted February 23, 2008 Share Posted February 23, 2008 Talk to Oilman there are a few very good alternatives to V160 oil, which is basically an ATF fluid. Link to comment Share on other sites More sharing options...
tDR Posted February 23, 2008 Share Posted February 23, 2008 Moved to tech as requested. 10w40 engine oil is very much the wrong oil to use, I'd get it changed quick smart! Cheers, Brian. Link to comment Share on other sites More sharing options...
Muffleman Posted February 23, 2008 Share Posted February 23, 2008 they filled it with 10w 40 Link to comment Share on other sites More sharing options...
Gaz Walker Posted February 23, 2008 Share Posted February 23, 2008 Link to comment Share on other sites More sharing options...
SilverSoop Posted February 23, 2008 Author Share Posted February 23, 2008 hmmm 10w40 doesnt sound right. i use 75w90 in my gearbox Yeh thanks all, i know thats what i said to the guy at gearlink but he was adament that the type he uses, he puts in every gearbox hes dealt with! Well, this isnt a normal gearbox, and i said to him it should have v160 gearbox oil.... Link to comment Share on other sites More sharing options...
SilverSoop Posted February 23, 2008 Author Share Posted February 23, 2008 Gaz, what gearbox oil would you use?? Link to comment Share on other sites More sharing options...
SilverSoop Posted February 23, 2008 Author Share Posted February 23, 2008 hmmm 10w40 doesnt sound right. i use 75w90 in my gearbox Ok so because you use that type, not trying to sound silly but whats that like for your gearbox?? Link to comment Share on other sites More sharing options...
supra matt Posted February 24, 2008 Share Posted February 24, 2008 http://www.mkivsupra.net/vbb/showthread.php?t=56684 Here you go mate Link to comment Share on other sites More sharing options...
AndyT Posted February 24, 2008 Share Posted February 24, 2008 Get the 10w 40 out mate it has no where near the correct properties to cope with the loads inflicted on it by gears meshing together. PM oilman too. Link to comment Share on other sites More sharing options...
SilverSoop Posted February 24, 2008 Author Share Posted February 24, 2008 Ok thanks guys, you have been a big help. Just one thing though, im going to get this oil out straightaway but do i have to drop the box to drain the oil or can it be done from being jacked up cos unfortunetely, i dont have a ramp to put her on. Oh yeh, does halfords or auto factors sell 75w 90 cos im going to put that in for the meantime until i get some v160 oil... Link to comment Share on other sites More sharing options...
uk-rich Posted February 24, 2008 Share Posted February 24, 2008 the drain plug is at the bottom of the box the fill plug is about half way up the side (passenger side) Link to comment Share on other sites More sharing options...
SilverSoop Posted February 24, 2008 Author Share Posted February 24, 2008 the drain plug is at the bottom of the box the fill plug is about half way up the side (passenger side) Ok thanks rich, to fill it up do i need to drop the box slightly because it looks quite hard to get to especially if im trying to fill it up.... Link to comment Share on other sites More sharing options...
Gaz Walker Posted February 24, 2008 Share Posted February 24, 2008 If you can get the V160 fluid use that, otherwise use a good fully synthetic 75w90 (Motul, Silkoline etc) oil. Gaz. Link to comment Share on other sites More sharing options...
SilverSoop Posted February 24, 2008 Author Share Posted February 24, 2008 If you can get the V160 fluid use that, otherwise use a good fully synthetic 75w90 (Motul, Silkoline etc) oil. Gaz. Pm'd Link to comment Share on other sites More sharing options...
supra matt Posted February 24, 2008 Share Posted February 24, 2008 to fill it up mate just pop the gear stick out allot easier then doing it from below . Link to comment Share on other sites More sharing options...
SilverSoop Posted February 24, 2008 Author Share Posted February 24, 2008 to fill it up mate just pop the gear stick out allot easier then doing it from below . Oh ok, is that an easy job? because i really dont like messing around with gearboxes too much as they have caused me a headache already!! Link to comment Share on other sites More sharing options...
Jake Posted February 28, 2008 Share Posted February 28, 2008 to fill it up mate just pop the gear stick out allot easier then doing it from below . Is that true? I want to top mine up for the new owner, as it has a weeping rear seal, but it's p!ssing down outside. It would be great if I could do it from inside the car. Hang on a mo . . . how do you know the correct level if you're just chucking it in from above? Link to comment Share on other sites More sharing options...
captainchaos Posted February 28, 2008 Share Posted February 28, 2008 try opie oils got all the fluids for my car from them very helpful and got a good discount Link to comment Share on other sites More sharing options...
gaz1 Posted February 28, 2008 Share Posted February 28, 2008 Ok thanks guys, you have been a big help. Just one thing though, im going to get this oil out straightaway but do i have to drop the box to drain the oil or can it be done from being jacked up cos unfortunetely, i dont have a ramp to put her on. Oh yeh, does halfords or auto factors sell 75w 90 cos im going to put that in for the meantime until i get some v160 oil... i got v160 oil from mr wiffin the very next day i ordered;) Link to comment Share on other sites More sharing options...
