Hub-centric spacers
Matt H
looks like i'm going to have to space my front wheels out slightly to clear the AP calipers as the offsets of my new wheels are slightly out :cry: by 6mm as well.. balls
Anyway, couple of queries;
- Can you get any smaller than 10mm?
- Anyone know where to get a pair from (traders)
Ta
Matt
6mm hubcentric is not possible to engineer.
Sorry to hear they don't fit Matt :(
Like b'have says its not possible to get lower than 10mm.
I sell Eibach hubcentric kits, TUV approved so high quality. Pricey mind, they are around £80 a kit.
Gaz.
Gaz.
So thats £160 for the pair. How fast can you turn that around including delivery to Knight Racer?
ta
I can make you some 6mm ones up Matt if you need it.
I was just asking if a custom set could be made due to people saying you can only get 10mm thick ones. I thought that might be minimum thickness etc.
Really, how come people are saying that you cant do shorter? thought it was too do with the stud?
Yes that's what I mean by the previous post, is there something other than them not being readily available in the size you want?
As you say like the studs etc.
I thought somebody like Gaz etc. might know more about it.
Ideally the tapped holes depth in the spacer that takes the studs needs to be 1.5 x the diameter of the stud.
Ah right, I didn't realise that the studs had to go into the spacers.
10mm does sound about right then for the minimum thickness.
Indeed that's right you should have 1.5 times the diameter in the hole.
