auto / manual box mounts the same?
johnd-mkiv
Sounds like they kept the auto trans tunnel top insted of patching in a manual one. The manual trans tunnel sits an inch higher.
How do you mean by patching in a manual one?
this is a pic of what I have from under the car looking up
inbetween the two welded keep nuts you can see two white spots this is where the gear lever lincage is banging on the floor
Thats your problem mate. Thats an auto trans tunnel top. It needs cutting out, and the manual one welding in. £30 odd from Toyota, easy enough to do if you know a welder. :)
Thanks jezz, thats saved me loads of time ;) dont spose yourself or anyone else would have a pic of this part as ill make one up at work
A part number for this pannel would be great if any one has it? as my local toyota garage dont seem the full ticket
You dont want to try to make it yourself. Not when you can buy a perfect fit for £30
but this is what you need I believe
PN 58804-14040 Upper Console - Panel Sub Assembly
Agreed, making one would be a PITA compared to paying £30 odd for a new one. The measurements have to be quite precise for the abs sensor mount and handbrake bolt threads.
