Gaz6002 Posted February 21, 2008 Share Posted February 21, 2008 As above really. How many fuel pumps do you run with your setup and why? Also, which brand/model are you using? I'm having issues with my twin Walboro setup and am considering reverting to a single one again or maybe a different make (Bosch 044?) for simplicities sake. What are peoples thoughts? Link to comment Share on other sites More sharing options...
Ian C Posted February 21, 2008 Share Posted February 21, 2008 My thoughts are use the search button that I use one Walbro -Ian Link to comment Share on other sites More sharing options...
Gaz6002 Posted February 21, 2008 Author Share Posted February 21, 2008 My thoughts are use the search button that I use one Walbro -Ian I have Ian - but you know how hard it is to find answers to specific questions from current setups Link to comment Share on other sites More sharing options...
Ian C Posted February 21, 2008 Share Posted February 21, 2008 I'm sure I crossed that bit out, I don't know why you're bringing it up Anyway, one Walbro can run a good amount of power for the street. T67 with cams, 1.4bar of boost, 720cc injectors, works fine. -Ian Link to comment Share on other sites More sharing options...
Wez Posted February 21, 2008 Share Posted February 21, 2008 Single Walbro here too, I dont like multi pump setups anyway Link to comment Share on other sites More sharing options...
Gaz6002 Posted February 21, 2008 Author Share Posted February 21, 2008 Single Walbro here too, I dont like multi pump setups anyway I'm beginning to LOATHE the bloody things Thanks guys, I think i've got the answer I need now. Link to comment Share on other sites More sharing options...
michael Posted February 21, 2008 Share Posted February 21, 2008 Single UK pump should do the trick. Link to comment Share on other sites More sharing options...
Ryan.G Posted February 21, 2008 Share Posted February 21, 2008 I'm beginning to LOATHE the bloody things Thanks guys, I think i've got the answer I need now. Whats wrong with yours Gaz? Link to comment Share on other sites More sharing options...
kylestt Posted February 21, 2008 Share Posted February 21, 2008 Twin Walbros here. A single pump can't support the horsepower I'm trying to achieve. Link to comment Share on other sites More sharing options...
rob wild Posted February 21, 2008 Share Posted February 21, 2008 This is a summary of my fuel set up: -8an lines Fuel cell modification 2 x Walbro fuel pump Aeromotive FPR Aeromotive -10 high pressure filter Relays Boost Logic fuel rail 880cc injectors Custom Injector clips Fuel rail connectors / fittings -8an pertek fuel lines 19 meters I'm sure Ryan could comment over the efficiency of the setup i.e. injector duty cycles etc etc Link to comment Share on other sites More sharing options...
Gaz6002 Posted February 21, 2008 Author Share Posted February 21, 2008 Whats wrong with yours Gaz? It appears to be wired in incorrectly as the pumps are fighting against each other causing the fuelling to be pretty much uncontrollable. I do have a temp fix for it but am looking at a long term solution to the problem. Link to comment Share on other sites More sharing options...
Wez Posted February 21, 2008 Share Posted February 21, 2008 Do you have the pumps feeding each end of the rail separately? Link to comment Share on other sites More sharing options...
kylestt Posted February 21, 2008 Share Posted February 21, 2008 It appears to be wired in incorrectly as the pumps are fighting against each other causing the fuelling to be pretty much uncontrollable. I do have a temp fix for it but am looking at a long term solution to the problem. Do you have relays to up keep the voltage up on the pumps? If you try and tie 2 pumps into the stock wiring of the stock fuel pump it wont know what to do hehe. The Walbros are designed for 12volts of flow if i remember right. Link to comment Share on other sites More sharing options...
Ryan.G Posted February 21, 2008 Share Posted February 21, 2008 It appears to be wired in incorrectly as the pumps are fighting against each other causing the fuelling to be pretty much uncontrollable. I do have a temp fix for it but am looking at a long term solution to the problem. How did Thor Map it like that then? Link to comment Share on other sites More sharing options...
Gaz6002 Posted February 21, 2008 Author Share Posted February 21, 2008 Do you have the pumps feeding each end of the rail separately? The pumps themselves are doing the job fine when the diagnostic port is bridged, but I don't like this solution. Thats why I'm trying to find a better way to arrange things. Development is fun. Link to comment Share on other sites More sharing options...
Gaz6002 Posted February 21, 2008 Author Share Posted February 21, 2008 Do you have relays to up keep the voltage up on the pumps? If you try and tie 2 pumps into the stock wiring of the stock fuel pump it wont know what to do hehe. The Walbros are designed for 12volts of flow if i remember right. It's a PHR fuel kit and all parts were used. The pumps should be getting 12v, not 9v. How did Thor Map it like that then? By putting a temp fix on by bridging the diagnostic port. Thats what I mean, I've got a temp fix but am looking for a better solution. Link to comment Share on other sites More sharing options...
Ryan.G Posted February 21, 2008 Share Posted February 21, 2008 By putting a temp fix on by bridging the diagnostic port. Thats what I mean, I've got a temp fix but am looking for a better solution. I thought they would have fixed that !! I remember it having to be like that when it went to Thor but all it would take is for them to put a Circuit Opening relay that is linked to the STA signal so when the engine is running it activates the relay and turns on the Pumps. You could then just wire a direct feed from the battery. Ask James @ ToyotaGT for a Circuit Opening relay and i will sort it out for you one night as that is not Safe matey. Ryan Link to comment Share on other sites More sharing options...
Gaz6002 Posted February 21, 2008 Author Share Posted February 21, 2008 I thought they would have fixed that !! I remember it having to be like that when it went to Thor but all it would take is for them to put a Circuit Opening relay that is linked to the STA signal so when the engine is running it activates the relay and turns on the Pumps. You could then just wire a direct feed from the battery. Ask James @ ToyotaGT for a Circuit Opening relay and i will sort it out for you one night as that is not Safe matey. Ryan It's cool mate, the car is off the road right now anyway until it's properly sorted. We had some other major wiring issues before we got to this point so Thor were mainly looking at those. We have only just realised that this was causing the under-lying fuelling problem and so they can't really be blamed for that. I'll be in touch for some mapping when it's sorted though Link to comment Share on other sites More sharing options...
ajazyasin Posted February 21, 2008 Share Posted February 21, 2008 wiring pumps is so easy(now mine is done!). Im running 2 walbros. each one has a separate line that goes to each end of a dual feed rail. The pumps are fed by a 12v source through a relay that runs off the original ecu dual volatage setup. Works a treat. Link to comment Share on other sites More sharing options...
Wez Posted February 21, 2008 Share Posted February 21, 2008 wiring pumps is so easy(now mine is done!). Im running 2 walbros. each one has a separate line that goes to each end of a dual feed rail. The pumps are fed by a 12v source through a relay that runs off the original ecu dual volatage setup. Works a treat. Have you got anything in place to detect the failure of one pump? Link to comment Share on other sites More sharing options...
Pig Posted February 21, 2008 Share Posted February 21, 2008 Single pump here too. Did have 2 but there was no point so 1 came out. Link to comment Share on other sites More sharing options...
AshBhp Posted February 21, 2008 Share Posted February 21, 2008 This might help Link to comment Share on other sites More sharing options...
Gaz6002 Posted February 21, 2008 Author Share Posted February 21, 2008 This might help Thanks mate I was looking at that earlier. Useful post Link to comment Share on other sites More sharing options...
