Steering Wheel Help
mrboost
Hi Guys
I have managed to get another freebie!!! Its a Top Secret Steering wheel, the quality of the wheel it self looks quite bad, Its came from a Import MR2, I have managed to repaint the wheel (colour coded) and had the replacement sticker made up.
I am off to buy a BOSS kit this dinner for it.
I am wanting to know the correct procedure of removal of standard wheel and any other points I should know off.
Can anyone help ?
I was going to disconnect the battery and then just remove the standard wheel hopefully without the air bag going off in my face!.
Boost
The airbag shouldn't go off that easy . There's two little plastic covers , one on either side of the wheel that come off to reveal a lug nut . Loosen these & the bag/pad should become loose (eventually) . You'll find some yellow wiring loom that connects to the airbag & needs to be disconnected . As far as I remember there's a bracket that may need to be removed also .
The safety aspect is entirely down to you (obviously), but I've done it & I reckon that it should be safe enough on a car that had not seen any accidents without being properly repaired (replaced sensors , control unit etc.) . I'm sure some would say that it's a risky business (& there is obviously some risk) but if they were that tempramental , they shouldn't be in a car in the 1st place .
I am open to criticism about this .:baa:
ps. I might be interested in your old steering wheel
Guest Nick Harris
Disconnect the battery and tie the leads away from it first or you can take your head off!
Watch out for static during removal.
What are you going to do with the Explosive charges etc?
