Jake Posted February 20, 2008 Share Posted February 20, 2008 Day off. Thought I'd have another look at my "no power to heater controls" problem. Looking at the speedo converter I'm not sure I've reconnected it back together correctly. On the speedo converter it says CK-DU-99 Red: 12v Green: Earth Yellow: KMH Signal Input Blue: Speedo Grey: ECU The Blue, Red and Green wires are all connected to the back of the speedo. (I know that part is correct because I haven't messed with that) The other two wires from the converter (1x yellow, 1x grey) both have a male bullet connector. There's also a wire spurred off the blue 'speedo' wire which seems to have been connected to the blue/red stripe wire which goes to the stock electrical socket into the back of the speedo. So, I've got two spare wires from the Speedo Converter ; a Yellow ('KMH Signal Input') and Grey ('ECU') Which one connects to the loom side of the Blue/Red wire? And which one connects to the loom side of the Pink/Grey wire. (The speedo end of the Pink/Grey wire has just been capped off, that's correct, is it? Thanks Quote Link to comment Share on other sites More sharing options...
SteveR Posted February 20, 2008 Share Posted February 20, 2008 the "ECU" wire should go to... ooh no hang on, you've got a VVTi. Quote Link to comment Share on other sites More sharing options...
Jake Posted February 20, 2008 Author Share Posted February 20, 2008 Looking at this : http://homepage.ntlworld.com/peter.betts/supra/TechTips/dsc_speedo_mph.jpg I reckon the Blue/Red wire from the loom goes to the Yellow: KMH Signal Input so the other one (Pink/Grey wire) must be the one that connects to (Grey: ECU) Quote Link to comment Share on other sites More sharing options...
SteveR Posted February 20, 2008 Share Posted February 20, 2008 Doh, I just spent ages finding that and get back to the thread feeling all smug to see you've found it. That sounds right to me, I just wanted to check there weren't any VVTi gotchyas Quote Link to comment Share on other sites More sharing options...
Jake Posted February 20, 2008 Author Share Posted February 20, 2008 Thanks anyway Steve, all sorted now. Quote Link to comment Share on other sites More sharing options...
SteveR Posted February 20, 2008 Share Posted February 20, 2008 Coolio Quote Link to comment Share on other sites More sharing options...
babou88 Posted August 28, 2016 Share Posted August 28, 2016 Hello, Sorry to recover such an old post, but I have the (almost) same speedo converter to fit : and it's ok for the Blue, Red and Green wires : and ok for the yellow one too ! (on the Blue/Red wire from the loom behind dash) but i can't find a pink/grey one to link on the grey of my speedo converter... i have just a pink one, or a red/grey one ... can someone help me for where does i need to link the grey one? my car is a 1998 vvti turbo jdm manual. thanks best regards bastien Quote Link to comment Share on other sites More sharing options...
babou88 Posted August 29, 2016 Share Posted August 29, 2016 Bump! nobody install speedo converter on a UK forum ?? can't pass my MOT or drive the car without a functionnal speedometer. have read this of course : http://www.mkivsupra.net/vbb/showthread.php?112141-How-To-Install-a-Speedo-Convertor-and-Delimiter but schématic doesn't work ... thanks Bastien Quote Link to comment Share on other sites More sharing options...
babou88 Posted August 31, 2016 Share Posted August 31, 2016 Hello, For information, if i can help someone if needed , after testing by myself : the grey wire on my speedo need to be connected to the pink one, on the loom side of course. best regards Bastien Quote Link to comment Share on other sites More sharing options...
markssupra Posted September 1, 2016 Share Posted September 1, 2016 That's very useful Bastien, glad you have got it working. I have a problem with my speedo and have the same converter. Where did you get your one? Quote Link to comment Share on other sites More sharing options...
babou88 Posted September 1, 2016 Share Posted September 1, 2016 i don't know because i have bought it used, but have searched on the web and it seems that sumopower sell it: http://www.driftworks.com/forum/technical/157582-speedo-converter-ck-un-09-a.html or you can find it new here too: http://www.ebay.co.uk/itm/Speedo-speedometer-converter-chip-E-SVA-IVA-KMH-to-MPH-CARTEK-CK-UN-09-/381390870446 best regards bastien Quote Link to comment Share on other sites More sharing options...
and1c Posted September 1, 2016 Share Posted September 1, 2016 Nice one. Cheers for the info Quote Link to comment Share on other sites More sharing options...
G9RGE Posted September 1, 2016 Share Posted September 1, 2016 That's very useful Bastien, glad you have got it working. I have a problem with my speedo and have the same converter. Where did you get your one? I have just removed the same convertor from mine as I have fitted UK clocks. I was going to advertise it over the weekend but if your interested pm me :-) Quote Link to comment Share on other sites More sharing options...
