Dann Posted February 20, 2008 Share Posted February 20, 2008 In the engine bay, were abouts on a N/A supra does the wire loom go through in to the dash I cannot seam to see it. On the gto it was at top drivers side same on my soarer but not on the supra. I have some gauges I want to install and dont really want to drill new holes in the bulk head was hoping to run the wires through the existing hole is. many thanks dann Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 20, 2008 Share Posted February 20, 2008 Through the big rubber bellow below the charcoal canister, passenger side top corner on a RHD car. Link to comment Share on other sites More sharing options...
Dann Posted February 20, 2008 Author Share Posted February 20, 2008 Thank you very much runs out to have a look. Link to comment Share on other sites More sharing options...
carl0s Posted February 20, 2008 Share Posted February 20, 2008 I could've sworn I did mine somewhere near the pedals. I think it was a rubber bung with nothing going through it until I made a hole in it. Was that a bad idea? Might have been nicer to use the existing loom's bung I suppose. Link to comment Share on other sites More sharing options...
Ric Posted February 20, 2008 Share Posted February 20, 2008 I could've sworn I did mine somewhere near the pedals. I think it was a rubber bung with nothing going through it until I made a hole in it. Was that a bad idea? Might have been nicer to use the existing loom's bung I suppose. yes there is one there, but only on autos, the cylinder for the clutch goes through that hole on manuals Link to comment Share on other sites More sharing options...
JustGav Posted February 20, 2008 Share Posted February 20, 2008 The engine's loom runs through the grommit up on the bulkhead on the passenger side, there are some other little bits of loom that run through a grommit on the drivers side as well. Link to comment Share on other sites More sharing options...
