what kind of brake discs
TopgunTT
What brake discs do people prefer, Grooved, Drilled or both? What are the pros and cons?
Stock, unless you want to spend big money on 2-piece discs (lighter than stock).
Grooves just reduce the braking area, drilled holes are prone to cracking.
http://www.project-mu.co.jp/e/images/parts/rotor/SCR-PRO_SLIT-FS.jpg
I stuck with stock discs until I started doing track days, even then I went with TRD discs which are virtually stock but for some grooves... which are supposed to aid frequent heavy braking sessions, I think with stock dics you'd get better performance for a emergency stop than those with slots and drilled holes.
