hadyn Posted January 21, 2005 Share Posted January 21, 2005 Went out to check the oil on the supe this morning before i went out to work after being stood on the flat overnight, and to my horror the oil was right on the low mark!! I then went to my local petrol station and lobbed in 3.5 litres of magnatec 10/40 to top it up and a bit beyond the full mark. Where is the oil going? No obvious blue smoke, no smoke at all. No signs of oil leaks on the floor or tray, engine bay is so clean you could eat your dinner off it. Could it possibly be the oil put in before i bought the car was way too thin??? Will be checking the oil now on a daily basis to see whats going on.. Any ideas? Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted January 21, 2005 Share Posted January 21, 2005 did u check the oil level when u bought it, if u didnt it probably needed top up then and now u have just noticed Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 21, 2005 Share Posted January 21, 2005 Agree with Jurgen, you need to monitor oil usage over the next 1000 miles or so. The 2JZ-GTE isn't known as a heavy oil burner, unless the turbos are tired or valve stem seals have hardened. or worse... not wanting to worry you Quote Link to comment Share on other sites More sharing options...
hadyn Posted January 21, 2005 Author Share Posted January 21, 2005 did u check the oil level when u bought it, if u didnt it probably needed top up then and now u have just noticed oil was on the half-way mark when i checked before buying it and they did a full oil change before i bought it. Oil was 1/4 down when i checked it at the start of the week..... No noises, rattles etc and pulls extremely well through the rev range with both turbos engaging when they should In fact, purrs on idle Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted January 21, 2005 Share Posted January 21, 2005 sorry to hijack, chris i believe one of my customers who bought a car of mine is taking his car to u, its an auto n/a. A think gareth eves also visited u, would be nice to get your opinion of the qualaty of the cars they have purchased of me, do u think they are of a good standard Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted January 21, 2005 Share Posted January 21, 2005 oil was on the half-way mark when i checked before buying it and they did a full oil change before i bought it. Oil was 1/4 down when i checked it at the start of the week..... No noises, rattles etc and pulls extremely well through the rev range with both turbos engaging when they should In fact, purrs on idle thats strange then, best let chris wilson advice you. Quote Link to comment Share on other sites More sharing options...
hadyn Posted January 21, 2005 Author Share Posted January 21, 2005 chris please advise, as itll be coming to you if somethings wrong Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 21, 2005 Share Posted January 21, 2005 sorry to hijack, chris i believe one of my customers who bought a car of mine is taking his car to u, its an auto n/a. A think gareth eves also visited u, would be nice to get your opinion of the qualaty of the cars they have purchased of me, do u think they are of a good standard The automatic, silver N/A is still here, going out tomorrow. Nice car, as was Gareths. Did you supply them both recently? If they are typical of your stock it's a credit to you, if you don't mind me saying so?! Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 21, 2005 Share Posted January 21, 2005 chris please advise, as itll be coming to you if somethings wrong Very hard for anyone to 100% diagnose excess oil usage. can be just one thing (say valve stem seals) or more than one thing, (a bit of stem seal wear, a bit of turbo wear, and a bit of bore wear / piston ring wear). As such effecting a guaranteed 100% cure short of a total engine rebuild can be all but impossible. One can usually take an eductaed guess and back it up with leakdown tests et ceera, but it's not an excat science i am afraid, if I'm being totally honest. I'll have look at it and run some tests with pleasure. Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted January 21, 2005 Share Posted January 21, 2005 The automatic, silver N/A is still here, going out tomorrow. Nice car, as was Gareths. Did you supply them both recently? If they are typical of your stock it's a credit to you, if you don't mind me saying so?! i supplied them both, i think they have both now had their cars for about 6 months each, the auto was grade 4 and the tt was 3.5 due to having done 67,000 miles which in jap land is quite a lot. i only had the tt for one week in stock. keep up the good work chris. Quote Link to comment Share on other sites More sharing options...
hadyn Posted January 23, 2005 Author Share Posted January 23, 2005 checked the oil again this morning and there doesnt appear to be any loss yet after about 90-100 miles, it's still overfilled to the wire very very strange, the real test will be after my 300 mile weekly commute to work to see if any oil disappears Quote Link to comment Share on other sites More sharing options...
CJ Posted January 23, 2005 Share Posted January 23, 2005 Haydn, without wishing to take work off CW, but surely if there is something wrong with the car it should go back to the guys that supplied it? As you said in another thread, it has 3 months warranty so they should put it right if need be. Quote Link to comment Share on other sites More sharing options...
hadyn Posted January 23, 2005 Author Share Posted January 23, 2005 It will do if it drinks any more oil CJ, but lets give it a week to see what happens. CW is local to me and i think his diagnosis would be of more value than some 'performance' garage who think they know about cars Quote Link to comment Share on other sites More sharing options...
CJ Posted January 23, 2005 Share Posted January 23, 2005 It will do if it drinks any more oil CJ, but lets give it a week to see what happens. CW is local to me and i think his diagnosis would be of more value than some 'performance' garage who think they know about cars Good thinking Batman Quote Link to comment Share on other sites More sharing options...
Ian R Posted January 23, 2005 Share Posted January 23, 2005 Haydn mate I wouldn't run the car overfilled with oil for too long or you might be getting a decat done faster than you think Quote Link to comment Share on other sites More sharing options...
hadyn Posted January 23, 2005 Author Share Posted January 23, 2005 when you say 'getting a decat done faster than you think' do you mean excess oil fouling the cats and wrecking them??? i know excess fuel fouling cats damages them Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 23, 2005 Share Posted January 23, 2005 Running it over filled, could cause it to blow an oil seal, also it could cause a lot of oil mist/vapour to go into the induction system, via the engine breathers. Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted February 6, 2007 Share Posted February 6, 2007 Did you find out what the problem is? Quote Link to comment Share on other sites More sharing options...
hadyn Posted February 6, 2007 Author Share Posted February 6, 2007 Yeah I wasnt letting the oil settle before checking. Its best to leave your car for about 1-2 hours on a flat surface before checking the oil. Never had a problem with my old Supe Quote Link to comment Share on other sites More sharing options...
