Injectors
dangerous brain
How do I go about doing that chap?
There should be a port on the regulator that will have a blanking plug in that you can screw a little manual gauge into. The one at the front on this pic of an Aeromotive FPR:-
http://www.mvpmotorsports.com/Merchant/aero_afpr1.jpg
Wait wait discount all that (all that being my many many edits so far) I've looked again...
The VVTI stocker is the pink on the left in both pics, the PE650 is on the right so that means you haven't got stockers as the tip is a different design, it looks more like a PE one?
I've confused myself now :)
-Ian
PS although I will re-add the fact I used Macro mode on the camera and got clear pictures :p nyer
That looks about the same. Why in everything thats sacred would they take out the existing injectors and stick the same bloody sized injectors back in??? That means for sure that my fuel pressure is sky rocket high as well. But hang on a mo in the second picture is the left one the 440? If it is then thats not mine as the holes are more like the right one but oval in shape.
Ah so perhaps they are in fact the 800cc sard units that look the same as those ones? With holes as big as they are it must be larger than 440cc injectors maybe even 800's? I haven't seen any pictures of injectors that suit that style ie look the same as the stock one other than them sard ones.
Can the stock ones be rebuilt with bigger apertures?
  • 1 month later...
