APEXi Induction Kit
redline Rooster
Hi, I'm thinking of ordering an APEXi induction kit for my Sup, seeing as I can get quite a bit off the normal price! :p
I was just wondering if anyone else had fitted one of these kits to thier car, and what they thought!?!?!?
I had an APEXi kit installed on my last car and was quite impressed by "freeness" of the engine when revving. That car how ever was not turbo'd!
anyway, i'm gonna wait for Mr. Postman!
L8R
Rooster
:devil:
Just installed a Apexi Powerflow on mine and it sounds a lot better (bit like a quite dump valve and woosh on turbo spin) but haven't really noticed an improvement on power.
It is best to have this on in combination with Exhaust and boost upgrade as its importance increases I believe.
You're more likely to be losing power unless you supply it with some air.......... the stock setup is considered superior to any aftermarket filter that is mounted in the stock position
but they do sound nice:sly:
Yeah i've heard that, so i'm currently working on a nice air ducting and aluminium cowl to keep that nasty heat away :p
I had the same thing with my last car, if you simply installed the kit like they said in the booklet it would have draw boiling air from the back of the engine bay!!!!! not very good at all! you may as well stuff a sock in your in take and save £110 on an induction kit!!! :)
this setup will bring cool air from the front of the car, but hopefully when its raining, no water should find its way up the due to the position on the intake!!....... i hope :eek:
L8R
rooster
