Curiosity: Auto & TipTronic
mawby
The gearboxes are almost the same, however the older box has speed sensor holes machined out...
Its the Gearbox control taht would be the problem as you cant fit the VVT ECu into a pre VVT engine...
Some how I think it would be cheaper to buy a VVT Tip!
What about this tied in with a nice paddle shift? http://www.latentsolutions.com/suprastickuv.html
$385 shipped, that's more like it! Doesn't tell you how you make the actual gear change tho, presume the shift mechanism is a separate dealy altogether.
From the manual:
Connect the serial port to a 16x2 serial display for an in car display of the current mode, gear, lockup, throttle, mph, and rpm!
^^^ sweeeet!
From the manual:
^^^ sweeeet!
It seems Rob the one that SBDJ posted is better after reading this thread http://www.mkivsupra.net/vbb/showthread.php?p=1745964#post1745964
And this post by Lyndon
http://www.mkivsupra.net/vbb/showpost.php?p=1745964&postcount=39
