Guest gzaerojon Posted February 15, 2008 Share Posted February 15, 2008 i'm after a 6 speed gear surround and also the plate the goes underneath, i have no idea what it's called but it's there aparently, does anyone know what i'm on about? car's in next week for 6 speed conversion so i could do with this asap Link to comment Share on other sites More sharing options...
Paul Whiffin Posted February 15, 2008 Share Posted February 15, 2008 I keep brand new gearshift surrounds in stock, this comes with the gear lever boot also, let me know if thats any good. Ta Link to comment Share on other sites More sharing options...
SEDGE Posted February 16, 2008 Share Posted February 16, 2008 i'm after a 6 speed gear surround and also the plate the goes underneath, i have no idea what it's called but it's there aparently, does anyone know what i'm on about? car's in next week for 6 speed conversion so i could do with this asap Do you mean the tunnel plate ? toyota do them for just over £40..brother had to buy one last month when he went 6 speed. Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted February 16, 2008 Share Posted February 16, 2008 Do you mean the tunnel plate ? toyota do them for just over £40..brother had to buy one last month when he went 6 speed. i'm not sure really, all i know is it's not the one the welds over the tunnel to take the gear linkage, it actually bolts on Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted February 19, 2008 Share Posted February 19, 2008 bumpski Link to comment Share on other sites More sharing options...
gaz1 Posted February 19, 2008 Share Posted February 19, 2008 i have a 6 speed panel you can have it for postage, or i will drop it at afr saturday matey, and i believe its a tunnel plate your after, its the plate that sits over the hole where the stick comes out, if its a conversion your doing then they will weld a plate over the existing hole as auto,s are bigger, but you will still need the tunnel plate:D i think;) Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted February 19, 2008 Share Posted February 19, 2008 i have a 6 speed panel you can have it for postage, or i will drop it at afr saturday matey, and i believe its a tunnel plate your after, its the plate that sits over the hole where the stick comes out, if its a conversion your doing then they will weld a plate over the existing hole as auto,s are bigger, but you will still need the tunnel plate:D i think;) Nice one Gaz, i think i'll be collecting my car from AFR on saturday so i could always catch you then? let me know what i owe you though so can the tunnel plate be removed from the manual car and re fitted to mine? Link to comment Share on other sites More sharing options...
gaz1 Posted February 19, 2008 Share Posted February 19, 2008 Nice one Gaz, i think i'll be collecting my car from AFR on saturday so i could always catch you then? let me know what i owe you though so can the tunnel plate be removed from the manual car and re fitted to mine? you can have it mate no charge, i think its a case of just swapping, not definate though but i am sure mine has just been bolted on, i would not think they would build a shell for auto and manuals:D Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted February 20, 2008 Share Posted February 20, 2008 you can have it mate no charge, i think its a case of just swapping, not definate though but i am sure mine has just been bolted on, i would not think they would build a shell for auto and manuals:D bolted on you say, and your car is still there? cheers Gaz, i owe you one Link to comment Share on other sites More sharing options...
