Paul372 Posted February 15, 2008 Share Posted February 15, 2008 i ve had these noise for a while now at first it wasnt to bad so i replaced the boot rubbers but the noise didnt go so i lefted it, but now its really loud every little bump in the road its constatly knocking a rattling from the rear of the supe and when i hit a little bump it chucks me to one side, so sonething has gone on the rear of my supe but what could it be and what should i look out for, what is the most command thing to go. am gonna jack it up and have a look tomorrow Quote Link to comment Share on other sites More sharing options...
Al Massey Posted February 15, 2008 Share Posted February 15, 2008 jack up the rear mate and have a good look, sounds like bearings have gone mate Quote Link to comment Share on other sites More sharing options...
miko_supra Posted February 15, 2008 Share Posted February 15, 2008 yeah as m45sey has said get it in the air and give everything a good looking. really try and move the rear wheels at first to check for any play (they shouldn't move at all) Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted February 15, 2008 Share Posted February 15, 2008 Sounds like a dodgy shock to me, I'm sure it will all become clear once you jack it up and have a butchers. Quote Link to comment Share on other sites More sharing options...
stealth Posted February 15, 2008 Share Posted February 15, 2008 I have a similar problem at the moment although not quite as violent as yours sounds with the chucking me to the sides etc. I read somewhere that it could be something to do with the Anti Roll bar, the links or something along those lines (sorry for being so vague, am new to Supra ownership, ask me a scooby question and I'll give you a sensible answere LOL) Quote Link to comment Share on other sites More sharing options...
Homer Posted February 15, 2008 Share Posted February 15, 2008 Shocks are the obvious cause, but also worth checking the subframe bolt torque Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted February 15, 2008 Share Posted February 15, 2008 If its chucking you to one side could also be wheel alignment, tyre pressures, wheel bearing, worn bush, plenty of things to look at. Quote Link to comment Share on other sites More sharing options...
Paul372 Posted February 16, 2008 Author Share Posted February 16, 2008 Sounds like a dodgy shock to me, I'm sure it will all become clear once you jack it up and have a butchers. thats what thought it could be it sounds like it Quote Link to comment Share on other sites More sharing options...
s crane Posted February 17, 2008 Share Posted February 17, 2008 I had the same problem on my supra, so i undone all the bolts on the shocks and anti rollbar links greased them up and put back together and all was ok, saved buying new shocks;) Quote Link to comment Share on other sites More sharing options...
Big Red One Posted February 18, 2008 Share Posted February 18, 2008 I had the same problem on my supra, so i undone all the bolts on the shocks and anti rollbar links greased them up and put back together and all was ok, saved buying new shocks;) thanks mate, i jacked the supe up weekend and i have yellow bilstein all round apart from one thats the drivers side rear its a grey shock thats the one that has gone so i do need a pair of new rear bilstein shocks, but i will grease everything up like you said cheers Quote Link to comment Share on other sites More sharing options...
