SilverMachine Posted January 20, 2005 Share Posted January 20, 2005 > Everything you've ever wanted to know in the Haynes Manual made easy, > read on... > > > Haynes: Rotate anticlockwise. > Translation: Clamp with mole grips then beat repeatedly with hammer > anticlockwise. > > Haynes: This is a snug fit. > Translation: You will skin your knuckles! > > Haynes: This is a tight fit. > Translation: Not a hope in hell matey! > > Haynes: As described in Chapter 7... > Translation: That'll teach you not to read through before you start, now > you are looking at scarey photos of the inside of a gearbox. > > Haynes: Pry... > Translation: Hammer a screwdriver into... > > Haynes: Undo... > Translation: Go buy a tin of WD40 (catering size). > > Haynes: Retain tiny spring... > Translation: "Jeez what was that, it nearly had my eye out"! > > Haynes: Press and rotate to remove bulb... > Translation: OK - that's the glass bit off, now fetch some good pliers to > dig out the bayonet part. > > Haynes: Lightly... > Translation: Start off lightly and build up till the veins on your > forehead are throbbing then re-check the manual because this can not be > 'lightly' what you are doing now. > > Haynes: Weekly checks... > Translation: If it isn't broken don't fix it! > > Haynes: Routine maintenance... > Translation: If it isn't broken... it's about to be! > > Haynes: One spanner rating. > Translation: Your Mum could do this... so how did you manage to botch it > up? > > Haynes: Two spanner rating. > Translation: Now you may think that you can do this because two is a low, > tiny, 'ikkle number... but you also thought the wiring diagram was a map > of the Tokyo underground (in fact that would have been more use to you). > > Haynes: Three spanner rating. > Translation: But Nova's are easy to maintain right... right? So you think > three Porsche spanners has got to be like a 'regular car' two spanner job. > > Haynes: Four spanner rating. > Translation: You are seriously considering this aren't you, you pleb! > > Haynes: Five spanner rating. > Translation: OK - but don't expect us to ride in it afterwards!!! > > Haynes: If not, you can fabricate your own special tool like this... > Translation: hahahahahahahahahahahahahahahahahahahahahaha!!!! > > Haynes: Compress... > Translation: Squeeze with all your might, jump up and down on, swear at, > throw at the garage wall, then search in the dark corner of the garage for > whilst muttering "bugger" repeatedly under your breath. > > Haynes: Inspect... > Translation: Squint at really hard and pretend you know what you are > looking at, then declare in a loud knowing voice to your wife "Yep, as I > thought, it's going to need a new one"! > > Haynes: Carefully... > Translation: You are about to maim yourself! > > Haynes: Retaining nut... > Translation: Yes, that's it, that big spherical blob of rust. > > Haynes: Get an assistant... > Translation: Prepare to humiliate yourself in front of someone you know. > > Haynes: Turning the engine will be easier with the spark pugs removed. > Translation: However, starting the engine afterwards will be much harder. > Once that sinking pit of your stomach feeling has subsided, you can start > to feel deeply ashamed as you gingerly refit the spark plugs. > > Haynes: Refitting is the reverse sequence to removal. > Translation: But you swear in different places. > > Haynes: Prise away plastic locating pegs... > Translation: Snap off... > > Haynes: Using a suitable drift... > Translation: The biggest nail in your tool box isn't a suitable drift! > > Haynes: Everyday toolkit > Translation: Ensure you have an RAC Card & Mobile Phone > > Haynes: Apply moderate heat... > Translation: Placing your mouth near it and huffing isn't moderate heat. > > Haynes: Index > Translation: List of all the things in the book bar the thing you want to > do! > > For Added Haynes Fun: > Go to the first section, Safety First, and read the bit about Hydrofluoric > Acid - do you really want the advice of a book that uses this form of > understatement???!!? > > Now look at the lovely colour section on body repairs - as you look at > these two pages say to yourself over and over until it sinks in "mine will > never look like that..." Quote Link to comment Share on other sites More sharing options...
Red Posted January 20, 2005 Share Posted January 20, 2005 lol!! quality! Quote Link to comment Share on other sites More sharing options...
SilverMachine Posted January 20, 2005 Author Share Posted January 20, 2005 lol!! quality! When I got sent this I PML so much that I had tears running down my face and couldn't see the computer screen. Glad it put a smile on your face! Gaz Quote Link to comment Share on other sites More sharing options...
