VVti
SupraTT2004
http://img118.exs.cx/img118/9061/redvvti2xe.jpg
Seems too good to be true, doesn't it.
I spoke to the seller, he seems like a good guy and he knows quite a lot about Supras. He owns one himself, besides this one. He knows it's cheaply priced but just wants to shift it.
  • Replies 54
I agree, saw that ad this morning, things just didn't add up, it's definitely got a pre-facelift front bumper and front wings?
and headlights.
Surely if he does know about Supra's, why doesn't he say it's a vvti?
'cos it isn't one? He might not know that all 1999 Supras had the VVTi engine.
I've seen a 1993 car on a 2001 plate - because if you first register the car on a private plate when it's imported. You can the re-register it for a new normal plate and it gets a registration in line with when it was first registered...if you see what I mean.
It's a loophole.
The Loophole is a bit weird. If you buy a 1994 car from Japan in 2003, and register it immediately on a private plate such as B19 BOY. When you remove the private plate from the vehicle, the DVLA will issue a plate that is related to the year that it is first registered in the UK, so would be and 03/53 plate. Once that number is on the vehicle, I believe that you can then add another private plate of you choice upto the new 03/53 registrations.
Have just spoken to the guy again about the car. As we were all saying about its a pre facelift model etc. Basically he had no idea about facelift and pre facelift models. and it is a prefacelift model.
He said the paperwork says its a 1999 model but am i wrong thinking that the car should be a facelift being that age?
but am i right in thinking that if its a 1999 model it should be a facelift because the guy didnt even no what a facelift was.
Most certainly, 1996 was the year when the facelift took place. As also mentioned earlier a 1999 Twin Turbo should also have the VVTI engine.
he wouldnt give it
He's a waste of space!
Would be good if a local member could check this car out?
