What I must change for 600 HP? [Photo Inside] Help me!!!!
Stiffl3r
I have a Twinturbo Stock...
Fuel pump, clutch, injector (440cc) stock...
This is some photoes..
http://img185.imageshack.us/img185/9150/halfenginede1.jpg
http://img72.imageshack.us/img72/7647/turboneticshs2.jpg
http://img217.imageshack.us/img217/8297/upengineyc4.jpg
http://img340.imageshack.us/img340/5746/turbonetics1tj3.jpg
http://img502.imageshack.us/img502/2918/intercoolertrustqd4.jpg
http://img441.imageshack.us/img441/9884/knko0.jpg
http://img247.imageshack.us/img247/8081/vista3quartirk2.jpg
http://img247.imageshack.us/img247/7021/frontalepu9.jpg
This is a Turbonetics T67..
And i would like 550 hp..
What i change?
Fuel Pump?injectors?Clutch?
Please tell me now the model what i necessary install for a correctly setup for 600 hp :)
Please give me a list of parts to change...
Thank you..
Sorry for my imperfect english but i'm Italian :(
:yeahthat: and well set up suspension and brakes!!
I'd replace all fluids, new filters etc too. Is there a decent wastegate to hold the boost as well? Depending on how it's mapped, you might want an electronic boost controller too
I have on car:
http://img250.imageshack.us/img250/2043/26112007674bq0.jpg
http://img526.imageshack.us/img526/2158/26112007675ml0.jpg
http://img520.imageshack.us/img520/9789/26112007676vy6.jpg
http://img442.imageshack.us/img442/6561/26112007678xy0.jpg
http://img442.imageshack.us/img442/7382/26112007677hn5.jpg
And Voltmeter, Boost Gauge, Gas Temperature Gauge, Pressure and Temperature Oil Gauge..
Please let me some image with Price If is possible :)
These are good:
Turbo Boost Controller
Fuel Pump
Clutch
Thank you..
OS Giken twin plate wont be needed for that power id think no??, v pricey, and hope u have a strong foot :D
Brakes should hold up if theyre the bigger, euro/uk spec ones? Just get some good fast road pads, and change all fluids obviously..with 600bhp i would DEFINITELY uprate the LSD
I have a Jspec, in the future i install D2 8 Piston with 330mm Front..
What's the LSD?
Limited Slip Differential. The stock one is a Torsen type.
Ah ok, thank you..
Now, i search the Pieces for take my engine at 550-600 hp and the prieces (if it's possible)..
If in the engine i change:
RC 1000 Fuel Injector
HKS FUel Rail Kit
Walbro 255L/hr Fuel Pump
HKS Fuel Pressure Regulator
Braided Fuel Lines
New OEM Toyota Fuel Filter
I must change the pistons?Or the up objects are sufficient (for the Fueling only) ??
