Speedo
Jamil
My speedo currently reads in MPH however it uses the KPH numbers on the speedo. This is not normally a problem, i have just got used to the numbers being small. But I am going to get some el-glo dials from the group buy and thinking about it these dials will not come with KPH on them. So the speedo will not be correct anymore. Hope that makes sense!
Does anyone have any ideas? Can i get the speedo converted correctly? because I am assuming it was converted incorrectly :search:
Any advise would be great :)
Cheers
I think you will have to take in to get it re-calibrated professionally to the new clocks.
Shouldn't be too difficult to get changed.
I'm going to have the same problem myself when I get them.
hope this helps
Cheers for the advice. Does anyone know who/where i can get this done?
Im looking into this at the moment, as my speedo currently goes up to 300mph :rolleyes: which gets on my nerves a bit. I got my conversion done here: http://www.protech-uk.co.uk they also do odometers (convert them to miles). I asked about swapping the 300mph for 180mph, they said they can do it "1.5hour £67.50+vat". Hope this helps
Shaun
Cheers for the advice Shaun, I will contact them and see what they can do. Mine is the same goes to 300mph!!
