Guest N1CK Posted February 12, 2008 Share Posted February 12, 2008 Hi guys, I'm looking into buying my first supra but need to know a bit more about them. What should I look out for when buying one etc. Should I go for a twin turbo or a non-turbo? Should I avoid imports? I don't really want an auto unless it has a tiptronic box or something similar, but I don't think the auto models do. I have joined another supra forum so have got a bit of info off there too. But the more advice I can get the better. Do you think I can get a decent one for around 8/9k? Any info greatly appreciated. And if you have one for sale, put up a link! Here's one I've seen (it's an auto though), what do you guys think? http://www.pistonheads.co.uk/sales/358199.htm Thanks again, Nick Quote Link to comment Share on other sites More sharing options...
Tom S Posted February 12, 2008 Share Posted February 12, 2008 nick, search for sale and look at JM Imports, what is your spend limit, age, insurance etc Quote Link to comment Share on other sites More sharing options...
hoff Posted February 12, 2008 Share Posted February 12, 2008 The one in the ad looks clean. I'd want to see milage and engine pics etc. As Tom says try Jurgen (JM Imports) or Paul Whiffin (Whiffbitz) to see what they have at the moment. Also there are some tidy cars on here for sale. Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted February 12, 2008 Share Posted February 12, 2008 Taken from another forum -Have someone cold start the car while you stand behind it watching the tailpipe, and look for gray smoke with a blue-ish tint (easiest to see in direct sunlight) -Let the car warm up and continue to stand behind the car checking for smoke -Now move to the front of the car, and open the hood. Listen for bad noises (Noticeable Injector Ticking is Normal) -Now go back and watch the tailpipe for smoke, have someone blip the throttle, while you watch for smoke, let it idle between the blips -Now do the same but have them mash the gas and rev it up till like 5000rpm or so -Now have a friend follow behind you in another car while you go for a test drive -Have him watch for smoke while you drive -Put it in 2nd gear, let the rpm drop to about 1500, and then stomp on it, and stay on it till redline, then let off the gas. Your friend should be watching for "gray/blue smoke". Just grey/black smoke is ok. -Smoke at cold start-up, leaving a stop-light, or throttle blipping from idle is valve stem seals. Smoke under boost, or after letting off of boost, or maybe when revving full throttle, is turbo seals. Smoking for no good reason, or if it doesn't stop pretty quickly is piston rings (may get better or worse when hot). -Your job while at full throttle in 2nd is making sure the turbos boost fine (smoothly), that you can feel full boost by 4500rpm or near it, and that you don't hear bad noises (slight turbo whistle/whine is ok, if it has an intake it will be noticeable) -Use all the gears in the transmission, and make sure it shifts fine (if it is a 6spd, it is going to feel and sound clunky too you, that’s normal. If the transmission makes "ball bearings in a can" sounds at idle or low speeds, that is 2-piece sprung flywheel and is normal) -While driving with the windows down, listen for clicking or popping noises coming from outside the car. (A POP when starting or stopping, or making a sharp low speed turn (maybe up a hill), is the drivers side engine mount. A clicking sound under initial mild acceleration or deceleration, that lasts for only a second or two then stops, and sounds exactly the same regardless of speed, is the rear upper control arm bushings. A clicking that changes with speed is wheel bearings) -Make sure the brakes work smoothly and reasonably quietly. When coming to a stop take your hand slightly off the wheel and make sure it stays straight. -Make sure the car tracks straight on flat roads. -A creaking noise from the hatch when turning up hill, means it needs rubber hatch bumpers. -Rattling from above you means the targa is loose (make sure the targa bolts loosen, and tighten back down smoothly) and make sure the targa wrench is there. -Make sure the rear hatch opens and closes fine, and that is stays up on it own. -Make sure all the doors open and close smoothly -If you can really smell the exhaust when coming to a stop, it has no cats -If when flooring it, the car pulls smoothly till ~4000rpm, and then rockets forward like getting hit with a semi, then it's BPU and not stock. If you can hardly feel a change over from the 1st turbo to both, then it's stock. -When checking under the car for leaks, don’t be alarmed by an oily sludge on the transmission and differential. That’s a greasy undercoating that Toyota applied. But check for fresh oil leaks, and check the rear CV joint boots for cracks. -If possible, look at the spot where the car normally parks. Check for fresh oil puddles or spots. If they say their other car caused the spot, don't believe them if it's a clean 1-2 year old car they are blaming it on. -Check the wheel rim, inside and out, for curb rash or bent rims. -Check for excessive or uneven wear on the tires -Check for cheap, or miss-matched tires -Look to see if all the little plastic panels and parts under the car all line-up, and are attached, and that paint is not where it shouldn't be (cracked under trays are not uncommon, don't be alarmed). Spend a fair amount of time on the ground, don't be afraid to get a little dirty. Also all the major body panels have the original VIN number visibly stuck on them, make sure they are all still there and are the right number. Look for missing, non-original, or out of place fasteners. All these things are possible signs off a collision. -Check for signs of rust in the wheel wells and inner fender -Check the condition of all the exposed rubber on the suspension joints -Make sure the power steering is smooth and quiet -Make sure the gaps in the body panels are all even. -Walk all around the car, and look at each panel at different angles. Looks for small dents and dings, and make sure the paint matches all around. -Look over the paint condition very closely -Check around all the glass to see if it has been replaced. Check the manufacturer information on the glass to see if they are all the same. -Make sure all the exterior lights work -Check the headlamps for cracks, moisture or fogging/yellowing (expect them too be fogged/yellowed if an earlier model) -Make sure to test every last switch in the car to make sure it works (power windows, locks, turn signals, light switch, dome lights, power seat, cruise control, everything). Use all the functions on the A/C and make sure they all work. Go from HOT to COLD A/C and make sure it's getting very hot, and very cold. If it has a factory alarm, make sure the key-fobs work. -Check the interior for excessive wear (cracked leather in the seat's side bolsters is pretty damn common). -Check all of the fluids, make sure the fluid isn't terrible. Open the oil fill cap, and look inside for sludge build-up (you shouldn't see any) -Find out what oil the use, and how often (don't trust their answer unless they have receipts) -Ask them if they have had any work done to it. If they have owned it for several years, and say they have done nothing to it, don't take that as being a completely good thing. -Ask if it has ever had modifications, and what. -Make sure it still has the spare tire, jack and wrenches, owners manual, and targa wrench. -Try to get the repair records -Do a Carfax.com check on the VIN # -Take it to a mechanic you trust AFTER you have done all this to get it checked out one last time before buying it. -If the owner refuses any of this, be suspicious. -Try to take a level-headed friend with you who you can trust. This may sound like a lot to do, but really it's not, most of these things take no more than a second to do. Make sure to always go look at a car on a bright sunny day, and make sure you and the seller will have plenty of time (don't rush anything) Any problems you find (and your likely to find a few) should not mean you shouldn't buy the car. But you need to know what you are getting into, and whether the price is reasonable. Always negotiate. People are almost always willing to come down some on their asking price. And be prepared to walk away as hard as it may be. Hope this helps. ------------------------ Also check for blue smoke when moving of from a short stop, red light fx. This is very typical for supras and is due to worn Valve Stem Seals. Its not too much of a worry as long as the puff isnt too great. As far as I can figure it doesnt hurt anything but its kind of a chore to fix since the head need to be taken off. Also listen for rattles from the trunk since the rubber stoppers for the hatch often is worn. Simple fix (although they can be hard to get off) but a good thing to knock the price down. Quote Link to comment Share on other sites More sharing options...
mawby Posted February 12, 2008 Share Posted February 12, 2008 Why not just take a look at our guide... http://www.mkivsupra.net/vbb/showthread.php?t=67644 Quote Link to comment Share on other sites More sharing options...
AndyT Posted February 12, 2008 Share Posted February 12, 2008 And welcome. Quote Link to comment Share on other sites More sharing options...
Jake Posted February 12, 2008 Share Posted February 12, 2008 If you could stretch to £9,995 geoffvalenti is selling his really nice 97 Tiptronic TT. I've seen the car and it's in excellent condition. Maybe have a chat to Geoff about it, he's a good guy. Edit: Here the ad for Geoff's car : http://www.mkivsupra.net/vbb/showthread.php?t=139331 Quote Link to comment Share on other sites More sharing options...
danny_silva Posted February 12, 2008 Share Posted February 12, 2008 buy mine.... £4000!!! manual n/a... cheap for insurance!! Quote Link to comment Share on other sites More sharing options...
xanderroan Posted February 12, 2008 Share Posted February 12, 2008 I only joined recently, and had already bought mine, but after spending some time on the forum looking at the cars for sales and peoples comments about the traders I would in retrospect have probably bought from JM Imports, Whifbitz or one of the club owners cars... just search around here or send JM the spec you want and price you can spend. Quote Link to comment Share on other sites More sharing options...
couv3z Posted February 13, 2008 Share Posted February 13, 2008 buy mine.... £4000!!! manual n/a... cheap for insurance!! not to spoil your post but.... as this guy is new as its a grey import, is not cheaper to insure! a stock uk spec TT would actully be cheaper to insure. but then again it all depends on points/NCB/post code lottery/insurance compnay Quote Link to comment Share on other sites More sharing options...
SupraAyf Posted February 13, 2008 Share Posted February 13, 2008 I only joined recently, and had already bought mine, but after spending some time on the forum looking at the cars for sales and peoples comments about the traders I would in retrospect have probably bought from JM Imports, Whifbitz or one of the club owners cars... just search around here or send JM the spec you want and price you can spend. Well said Alex;) Quote Link to comment Share on other sites More sharing options...
Dave Posted February 13, 2008 Share Posted February 13, 2008 this ones my sons car its in very nice condition just had the bonnet resprayed spoiler and wing mirrors http://www.mkivsupra.net/vbb/showthread.php?t=139539 Quote Link to comment Share on other sites More sharing options...
Guest O-Jay Posted February 13, 2008 Share Posted February 13, 2008 Just joined the forum because I will hopefully be getting a Supra by summer (later this year). Trying to give myself plenty of time to brush up on what I need to know. Just wanted to say thanks for the great advice on this thread fellas Quote Link to comment Share on other sites More sharing options...
Fifty Posted February 13, 2008 Share Posted February 13, 2008 nice post but "If when flooring it, the car pulls smoothly till ~4000rpm, and then rockets forward like getting hit with a semi, then it's BPU and not stock. If you can hardly feel a change over from the 1st turbo to both, then it's stock." Really? - how strange the fairies must have BPU'd mine then Rich Quote Link to comment Share on other sites More sharing options...
Blackie Posted February 13, 2008 Share Posted February 13, 2008 not to spoil your post but.... as this guy is new as its a grey import, is not cheaper to insure! whats a "Grey import"? Quote Link to comment Share on other sites More sharing options...
CJ Posted February 13, 2008 Share Posted February 13, 2008 If you could stretch to £9,995 geoffvalenti is selling his really nice 97 Tiptronic TT. I've seen the car and it's in excellent condition. Maybe have a chat to Geoff about it, he's a good guy. Edit: Here the ad for Geoff's car : http://www.mkivsupra.net/vbb/showthread.php?t=139331 I would second that. It's a very nice car that has been very well looked after. Quote Link to comment Share on other sites More sharing options...
mawby Posted February 13, 2008 Share Posted February 13, 2008 whats a "Grey import"?Not imported by the manufacture - imported privately after having been previously registered in another country. Quote Link to comment Share on other sites More sharing options...
Blackie Posted February 13, 2008 Share Posted February 13, 2008 Not imported by the manufacture - imported privately after having been previously registered in another country. Cheers Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted February 13, 2008 Share Posted February 13, 2008 Really? - how strange the fairies must have BPU'd mine then Rich LOL yeah what a load of crap Quote Link to comment Share on other sites More sharing options...
adam bell Posted February 13, 2008 Share Posted February 13, 2008 i wouldnt feel happy being hit by a semi Quote Link to comment Share on other sites More sharing options...
RedM Posted February 13, 2008 Share Posted February 13, 2008 i wouldnt feel happy being hit by a semi I'll ask my girlfriend what it feels like. Quote Link to comment Share on other sites More sharing options...
adam bell Posted February 13, 2008 Share Posted February 13, 2008 I'll ask my girlfriend what it feels like. she loves it the dirty cow Quote Link to comment Share on other sites More sharing options...
RedM Posted February 13, 2008 Share Posted February 13, 2008 she loves it the dirty cow Damn. I can't find the penalty for insulting a mods bird! Quote Link to comment Share on other sites More sharing options...
Class One Posted February 13, 2008 Share Posted February 13, 2008 i wouldnt feel happy being hit by a semi I'll ask my girlfriend what it feels like. Henman fever Martin? Quote Link to comment Share on other sites More sharing options...
RedM Posted February 13, 2008 Share Posted February 13, 2008 Henman fever Martin? Nope. Don't get it. Quote Link to comment Share on other sites More sharing options...
