Fuel cut ? warning light.
Harllequin
Hi guys I think I have experiance fuel cut.
Car =
93 GX
Induction kit
first cat in place
second decat
3inch stainless from first cat.
Thats as much as I think has been done.
I booted it today and then you would think I hit a brick wall. However after reading several posts on here I did not see any warning light. Should this have come on. As soon as the drop in power happened i backed off the throttle right away.
I have a boost guage in the car and it was showing right on the 1 bar mark.
Basicaly I think I hit Fuel Cut, but had no warning light.
1. Was i right with fuel cut?
2. Should I have seen a warning light.
cheers in advance guys
Darren
I've hit this a couple of times in the last few weeks. When it happens I also get the engine malfunction light on (orange engine light). Does this light work on your car?
I'm just guessing here, but the red triangle should only aluminate to warn you that another warning light is on. It is possible that if the other light doesn't work then maybe that will also prevent the red triangle from working.
