Eboost 2
flyby
They are very popular here in Australia - well designed and great value for money...
Some nice features too:
* Factory Preset Mode provides beginners with an easy start-up option
* Advanced Mode unlocks up to 6 alternate boost mapping functions suitable for FWD, RWD, AWD, Bike and Drag racing needs
* Gear-based Boost Mapping – set a different boost for each gear!
* Boost levels can also be mapped against TIME or RPM.
* Fully programmable auxilary output controls water spray, methanol or nitrous injection against Boost or RPM
* RPM Compensation Feature eliminates boost drop-off at high RPM
* Peak Hold/Max Boost Recall function monitors boost and RPM.
* Display can be configured to KPA, Bar or PSI
* Gate Pressure function eliminates wastegate creep
* e-Boost2’s display is accurate to within +/-0.5% of full scale making it an ideal Boost Gauge!
* Programmable, audible warning alarm
* Integrated input for optional shift/warning lights
I used to use an E-boost 1 on my Coupe turbo and it was a great piece of kit, easy to setup and use.
A good friend of mine has started importing Gizzmo electronics (he was the sole importer for the UK last time I spoke to him) from Oz and they seem to have a good reputuation like turbosmart.
They are cheaper than all the other controllers too. They do a multi-stage controller for something like £180.
