Homer Posted February 10, 2008 Share Posted February 10, 2008 Does anyone have any bright ideas on how to block off the hole for the rear wiper arm? I don't want to involve filler or paint, so am just looking for some sort of bung... It doesn't need to be pretty, just some basic black rubber bung to fill the hole it creates would do the job Quote Link to comment Share on other sites More sharing options...
Guest CoolsBlue Posted February 10, 2008 Share Posted February 10, 2008 rubber grommet from your local auto place, halfords will Quote Link to comment Share on other sites More sharing options...
uk-rich Posted February 10, 2008 Share Posted February 10, 2008 maplins sell blanking grommits Quote Link to comment Share on other sites More sharing options...
Homer Posted February 10, 2008 Author Share Posted February 10, 2008 Watertight one's? I've tried Maplins before and nothing they had fitted (not even close) same with halfords. Quote Link to comment Share on other sites More sharing options...
Jazzy Posted February 10, 2008 Share Posted February 10, 2008 What about a blanking grommet from somewhere like B&Q or equivalent? Quote Link to comment Share on other sites More sharing options...
Homer Posted February 10, 2008 Author Share Posted February 10, 2008 What about a blanking grommet from somewhere like B&Q or equivalent? Already tried them, there's nothing they supply that fits. Guys, I'm looking for something that is a water tight fit, not a bodge Quote Link to comment Share on other sites More sharing options...
GoliathJay Posted February 10, 2008 Share Posted February 10, 2008 Only my Preude I got a blanking grommit from Halfords, 25mm, and just put some epoxy resin round it, made a nice tight fit. I have painted the blanks before, and it take uite well. If you prime it it will help. Quote Link to comment Share on other sites More sharing options...
Kev.O Posted February 11, 2008 Share Posted February 11, 2008 Any idea what size diameter the hole is Homer? Quote Link to comment Share on other sites More sharing options...
Homer Posted February 11, 2008 Author Share Posted February 11, 2008 Any idea what size diameter the hole is Homer? At a rough guess, 24-28mm, but can measure tomorrow Quote Link to comment Share on other sites More sharing options...
Kev.O Posted February 11, 2008 Share Posted February 11, 2008 At a rough guess, 24-28mm, but can measure tomorrow I haven't got anything waterproof in mind (my 25mm blind grommet idea isn't waterproof) but thought it might help you Quote Link to comment Share on other sites More sharing options...
colsoop Posted February 11, 2008 Share Posted February 11, 2008 As said earlier a grommet from Halfords. Then just run a bead of silicone (underneath) around the grommet edges. I have had one on like that for over 6 months. Quote Link to comment Share on other sites More sharing options...
Guest CoolsBlue Posted February 11, 2008 Share Posted February 11, 2008 local auto shop have these kinds, all different sizes, should have a wall with packs of bits n bobs, switches, numberplate sticky pads, screws etc and these kind of flexible rubber grommets for 85p around that mark Quote Link to comment Share on other sites More sharing options...
Inferno Posted February 11, 2008 Share Posted February 11, 2008 Hope this helps: http://supraforums.com/forum/showthread.php?t=443217 Quote Link to comment Share on other sites More sharing options...
Pabs Posted March 16, 2008 Share Posted March 16, 2008 bump on this thread - Homer you sorted this now? From reading SF - it appears the hole is 34mm - there are lots of "blanking grommits" on ebay which are either 32mm or 37.3mm, wondered if these may do the job? Also - if you've removed the rear wiper - did you remove motor/pipes etc as well? Any info is great - thanks! Quote Link to comment Share on other sites More sharing options...
Homer Posted March 16, 2008 Author Share Posted March 16, 2008 All sorted now mate, I picked up a blanking plug while at Jezz's place. Fitted it a few weeks ago and it's been perfectly water tight after all this rain! The wiper and motor was already gone, so only filled the hole. If you don't get an answer by tomorrow I can take a measurement of the hole for you. Let me know. Quote Link to comment Share on other sites More sharing options...
Pabs Posted March 16, 2008 Share Posted March 16, 2008 did you use some sealant etc as well? Quote Link to comment Share on other sites More sharing options...
Homer Posted March 16, 2008 Author Share Posted March 16, 2008 did you use some sealant etc as well? No, just fitted the plug. It was pretty snug so didn't see the need for any sealant Quote Link to comment Share on other sites More sharing options...
Pabs Posted March 16, 2008 Share Posted March 16, 2008 No, just fitted the plug. It was pretty snug so didn't see the need for any sealant Cool - thanks EDIT - just saw your edit on previous post! Quote Link to comment Share on other sites More sharing options...
Homer Posted March 16, 2008 Author Share Posted March 16, 2008 Cool - thanks What did you do with motor/hoses etc? The hose for the washer jet is still there but I'll just leave that in place. The wiper arm and motor were missing from the boot lid when I got it. Quote Link to comment Share on other sites More sharing options...
Pabs Posted March 16, 2008 Share Posted March 16, 2008 EDIT: ignore me - I'm a numpty. Quote Link to comment Share on other sites More sharing options...
Pabs Posted March 29, 2008 Share Posted March 29, 2008 Has anyone got a rough "how to" on removing the rear wiper arm, motor etc? ta Quote Link to comment Share on other sites More sharing options...
Guest CoolsBlue Posted March 29, 2008 Share Posted March 29, 2008 i duno....but i do have a rubbere grommet to blank the hole somewhere! Quote Link to comment Share on other sites More sharing options...
merckx Posted March 30, 2008 Share Posted March 30, 2008 Has anyone got a rough "how to" on removing the rear wiper arm, motor etc? ta Wiper arms are normally fitted onto a splined shaft, so pull loose the cover where the wiper pivots, remove the nut then lever off the wiper arm. There's normally a larger nut you then have to remove. The rest is common sense, obviously the motor assembly has to be removed from the other side. Quote Link to comment Share on other sites More sharing options...
Pabs Posted March 30, 2008 Share Posted March 30, 2008 thanks mate - I was hoping for a guide on how to get to the wiper motor itself - I assume it means removing the trim from under the hatch, but I'm not 100% sure how the trim is held onto the car. Quote Link to comment Share on other sites More sharing options...
Pabs Posted April 4, 2008 Share Posted April 4, 2008 well I can't find a 34mm grommet/bung/cable gland anywhere... am I right in assuming peeps used slightly bigger ones? Quote Link to comment Share on other sites More sharing options...
