Engine pinging noise
Guest Ecossesupra
Guest Ecossesupra
Hello all,
Any suggestions what to do about a bizzare pinging sound my 93n/a is making, after a bit of research can see it may be a result of detonation but aint got no turbos?!?! mores the pity. Could it be a duff knock sensor, plugs etc. My car is a jap import, 40k on the clock, looks like it has a full jap service history.
Any help would be greatly appreciated.
Cheers
Keith
Don't tell me, it only does it on fairly wide throttle openings in a high gear, where you maybe should have changed down ;)
Have you checked the ignition timing? I'm not sure whether its adjustable on the N/A (it isn't on the TT)
What fuel are you running on, Optimax/super unleaded, std unleaded or paraffin :)
Guest Ecossesupra
I run it on vodka lol, I have tried optimax etc makes b*gger all difference, not sure about timing got a feeling I cant adjust it though. If I drive real slow I cant here it, but as I accelerate a bit harder it becomes more noticable. ping ping ping ping pong ping!
K
Sounds like the ignition timing might be out to me (too advanced). While you’re checking the distributor cap, check that the whole distributor has not come loose, make sure you can’t rotate the whole distributor assembly by hand. I would definitely get the timing checked as a first step as this is very easy to do and shouldn’t cost too much if you have to take it somewhere to get it done.
Does anybody know if the NA uses a vacuum advance? Either way the mechanism that advances the timing at higher revs might be at fault, if pinking is occurring then I would suspect too much advance, check all the hoses that go anywhere near the distributor for leaks too.
Best of luck.
Guest Ecossesupra
Thanks for that mate, will check all these things, I appreciate your help as I am used to working on sixities american cars which are a bit less technically advanced......
The car is due a service so will get them to check out the timing at the same time, it does sound like a timing thing.
Cheers
Keith
