Guigsy Posted June 25, 2013 Share Posted June 25, 2013 Also to add I think the front section. Are no longer available from Toyota. And the garage had to make some up. Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted June 25, 2013 Share Posted June 25, 2013 Can you buy aftermarket? Quote Link to comment Share on other sites More sharing options...
Guigsy Posted June 25, 2013 Share Posted June 25, 2013 Not difficult to make if the garage has all the equipment. Iv never seen aftermarket ones. The main ones that go at the rear are available but I wanted them all done. Quote Link to comment Share on other sites More sharing options...
slow8dirty Posted August 4, 2013 Share Posted August 4, 2013 Yup, reckon mine needed doing Quote Link to comment Share on other sites More sharing options...
Guest Roger NE Posted September 11, 2013 Share Posted September 11, 2013 (edited) Just looked at this old thread . . . . I've always cleaned and undersealed my brake and fuel lines (where they are on the underside of the car) to reduce the chance of corrosion, so I'd recommend that (I've always checked and topped up the underseal on the whole underside of the car every year anyway) Incidentally, any sign of corrosion on a Brake Line is an MOT fail . . . . but on a Fuel Line it will only fail if it's actually leaking ! Edited September 11, 2013 by Roger NE (see edit history) Quote Link to comment Share on other sites More sharing options...
monsween Posted September 11, 2013 Share Posted September 11, 2013 This is behind a plastic cover so do you take the cover off to deal them? Quote Link to comment Share on other sites More sharing options...
Dnk Posted September 11, 2013 Share Posted September 11, 2013 Easy enough to replace with copper if you have the brake pipe flaring tool, Halfords sell a kit for under £40 Quote Link to comment Share on other sites More sharing options...
Guest Roger NE Posted September 11, 2013 Share Posted September 11, 2013 This is behind a plastic cover so do you take the cover off to deal them? Well the worst area is around the rear of the car - important to properly clean and spray those In terms of the ones that run from front to rear in the plastic trunking, I usually just spray through the slots Quote Link to comment Share on other sites More sharing options...
soulfreak Posted February 14, 2014 Share Posted February 14, 2014 Just made a search thru topic but can't find a correct brake line diameter and fitting model/number. Please some one can tell these number. I want to buy a new copper lines and fittings and bent them. Quote Link to comment Share on other sites More sharing options...
scott87 Posted February 14, 2014 Share Posted February 14, 2014 Just made a search thru topic but can't find a correct brake line diameter and fitting model/number. Please some one can tell these number. I want to buy a new copper lines and fittings and bent them. Just saw your not from the uk my post doesnt help sorry Quote Link to comment Share on other sites More sharing options...
soulfreak Posted February 14, 2014 Share Posted February 14, 2014 Yes, I'm from Latvia, but it doesn't matter, Car is 93. J-Spec NA. I'm converting it right now to LHD and need to replace front brake lines. I forgot at home a sample to show in parts store. Quote Link to comment Share on other sites More sharing options...
scott87 Posted February 14, 2014 Share Posted February 14, 2014 Yes, I'm from Latvia, but it doesn't matter, Car is 93. J-Spec NA. I'm converting it right now to LHD and need to replace front brake lines. I forgot at home a sample to show in parts store. Yer sorry my question referred to going to halfords. Not sure they are in Latvia. Quote Link to comment Share on other sites More sharing options...
soulfreak Posted February 14, 2014 Share Posted February 14, 2014 Actualy I hate those suggestions when someone sends me to somewhere. I need numbers not store names I'm not sure that seller at part store will know exact size and fitting profile. Quote Link to comment Share on other sites More sharing options...
Guigsy Posted February 14, 2014 Share Posted February 14, 2014 I'm not sure if halfords know what brake lines are. Unless you have a bike Quote Link to comment Share on other sites More sharing options...
thomo8568 Posted March 11, 2014 Share Posted March 11, 2014 Hi Just noticed an oil patch by rear left wheel. When I checked under car, it looks like all 5 pipes are past there best. What size copper pipe have people been fitting for brakes and fuel? What size are the male ends used? As thinking of having a go at making my own. Quote Link to comment Share on other sites More sharing options...
N-Mir Posted March 13, 2014 Share Posted March 13, 2014 Hello, just wondering is it best to buy an exact replacement from toyota or replace with copper? Which method is best even if it cost more? Thank you Quote Link to comment Share on other sites More sharing options...
Alex Posted March 13, 2014 Share Posted March 13, 2014 hello, just wondering is it best to buy an exact replacement from toyota or replace with copper? Which method is best even if it cost more? Thank you oem. Quote Link to comment Share on other sites More sharing options...
thomo8568 Posted March 14, 2014 Share Posted March 14, 2014 Just been down to local toyota. Brake pipes T47327-14030 £46.78 T47326-14040 £39.55 T47328-14030 £17.68 Fuel lines T77251-14420 £27.70 T77255-14420 £50.07 +vat Not sure why one of the fuel lines is twice as much as other. Just hope there the right ones. Quote Link to comment Share on other sites More sharing options...
N-Mir Posted March 15, 2014 Share Posted March 15, 2014 Thanks alex and thomo, I remember going to kwick fit last year and the man said ill replace them with copper, I know people do this a lot with standard cars wasn't sure about on a sports car. Do some garages give club member discounts I remember reading we did a long time ago but some people have been refused recently. Quote Link to comment Share on other sites More sharing options...
jonny mac Posted April 16, 2014 Share Posted April 16, 2014 (edited) this may sound odd but this is why you have yearly mot's, so things like this won't happen, surely your brake pipes were advised during the last mot test? as brake pipes don't just suddenly go from fine to rotten/splitting open within a year. they can sit rusty for years before splitting/bursting. I done one of the pipes on monsween's supra a few years ago, they are really simple on a supra and took half an hour ish. a simple flaring tool for £10 and a roll of pipe £7-8 plus a top up of fluid should do the trick, new nuts are an option too but if you're stuck you can use the old ones. Edited April 16, 2014 by jonny mac (see edit history) Quote Link to comment Share on other sites More sharing options...
Annabella Posted March 10, 2016 Share Posted March 10, 2016 Just to give this a bump DO CHECK YOURS! Fitted caliper today, all good, drove it out of garage to jack it up and fit exhaust, fuel leaking onto existing exhaust Surprise surprise under the plate listed above corroded fuel return line, and as stated above all the rest that is visible looks fine. Brake lines are ok. PS does the blanking/cover plate really need refitting as it'll cause the same prob again? Or is it a necessary evil to stop random stones hitting it? Quote Link to comment Share on other sites More sharing options...
Supra2jze Posted June 27, 2016 Share Posted June 27, 2016 (edited) Just been down to local toyota. Brake pipes T47327-14030 £46.78 T47326-14040 £39.55 T47328-14030 £17.68 Fuel lines T77251-14420 £27.70 T77255-14420 £50.07 +vat Not sure why one of the fuel lines is twice as much as other. Just hope there the right ones. Just dropped my Supra off to the garage to have new braided brake lines all round..., my mechanic noticed my fuel line is leaking slightly, after removing the plastic cover the fuel lines are corroded & also need replacing. Edited July 21, 2016 by Supra2jze (see edit history) Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted October 8, 2016 Share Posted October 8, 2016 Thanks for the heads up on this, I checked mine this morning (20 year old UK spec) and have no issues. Easy to check and definitely worth doing! Quote Link to comment Share on other sites More sharing options...
rider Posted June 20, 2017 Share Posted June 20, 2017 (edited) Just been down to local toyota. Brake pipes T47327-14030 £46.78 T47326-14040 £39.55 T47328-14030 £17.68 Fuel lines T77251-14420 £27.70 T77255-14420 £50.07 +vat Not sure why one of the fuel lines is twice as much as other. Just hope there the right ones. Most of these are now discontinued. Does anyone know the od and id of the fuel and brake lines as they now need to be fabricated. Update - Steve Manley at Toyota Oxford has managed, according to a call to me today, to source a complete set of the four main front to back fuel and brake pipes. This is likely to be one of the last complete sets so anyone looking to do this at some point in the future with OE parts has a short time to actually source the OE parts. Edited June 21, 2017 by rider (see edit history) Quote Link to comment Share on other sites More sharing options...
Tyson Posted August 7, 2018 Share Posted August 7, 2018 Just a bump and a reminder about these. Thankfully mine failed whilst they were being tested on the mot. Rear pipe exploded covering a nice portion of the workshop in brake fluid Quote Link to comment Share on other sites More sharing options...
