WARNING 15 year old brake line rotted through
paul mac
I've got a leak somewhere.
Had to top my brake fluid up recently (http://www.mkivsupra.net/vbb/showthread.php?275750-Handbrake-lights-keep-coming-on) but the light has just come back on again so I've definitely got a leak somewhere.
Think I might take advantage of the free 37 point inspection at Toyota (http://www.mkivsupra.net/vbb/showthread.php?276962-Toyota-s-free-37point-visual-inspection&highlight=inspection) and see what they find :(
  • 2 weeks later...
Just had this very issue today, while prepping my car for its MOT ( putting the cat back in and putting legal plates on ) I noticed oily patches all over the drive and a smell of fuel. Stripped off the placcy covers and there is a lot of corrosion at every plastic bracket. Seems fuel and brake oil are mixing.
Frightening when I consider the level of "enthusiasm" with which I drove home.
  • 2 weeks later...
£837 :badmood:
Toyota quoted me £200 to replace these lines. He said they wouldnt bother with toyota parts and they would just bend some new copper pipe in its place....
That's very cheap for Toyota, Inchcape in Oxford are £120 per hour inc vat just on the labour.
Were they replacing the whole lot or just part of the system ?
Replacing the whole lot. He said it would be a really quick job, max couple hours and the copper pipe would only be around £30..... I was going to do it myself and buy a flare from ebay but at this price i may just save myself some time.
Brake pipes cheap, but fuel lines are a complete all out job and the rear frame and tank needs to be dropped for that. There was a full 70 litres in there too, so that needed storing. Hopefully I've got it all back. It was some 14 hours labour at £35 an hour at an independant local garage.
Sounds like a huge job. Could they not have cut the furl line where it was good just up behind the sub frame, flaired it and joined to new pipe? I assume thats what Toyota will do with mine if it is really that big a job they wouldn't have quoted so low for so much work....
- - - Updated - - -
I had the fuel lines done on my UK spec, the rear subframe didn't need dropping. Took my mechanic 4 hours. It was the first time he'd ever worked on a Supra too.
My local garage had a look at mine while it was on their ramp getting its MOT and he didn't see
any major dramas
Hmmm, garage said the fuel line was all one piece. They have always been a very trustworthy garage so I don't think they would deliberately shaft me.
Im sure as a standard toyota part it is and i bet its very expensive. I was meaning they could have cut it, flaired the old pipe and connected in a new section. Not 100% sure if its possible but you can do it with brake lines so im assuming you could with a fuel line.
Fair point. I'm hoping to sell it here so at least its had a proper job done now. It is the first major piece of work I've had to have done on the car since the very first cambelt job back at Sidcup in 2001 ish.
Very true. Just another reminder i need to get mine done....
  • 3 months later...
  • 2 months later...
  • 1 month later...
  • 3 weeks later...
Just had mine done by a local garage who were recommended to me for this kind of work. I haven't seen the job in person yet but I asked them to replace all four lines from front to back and especially the bit where they hop up over the driveshaft as the fuel line there was gone. They have charged me £170 cash.
The car is going straight into an MOT when I pick it up as it is currently SORNed, so I will report back after that! :)
