madmunky Posted February 10, 2008 Share Posted February 10, 2008 Im in the middle of placing my heater matrix but in the process ive notice how much stuff is there which i dont use. The pipes which run though the firewall to the Aircon unit as i dont use the air con or have the unit fited from when the FMIC was fitted can I just remove these pipes? Also I dont want the ABS in my car its never worked since i brought the car and dont really want it. Can I remove all the ECU's and bits which sit behind the dash without any problems? (will the engine error light report a problem with the ECU?) Quote Link to comment Share on other sites More sharing options...
madmunky Posted February 11, 2008 Author Share Posted February 11, 2008 Anyone got any ideas about this, my main consern is that the ECU will report errors with the ABS unit missing? Quote Link to comment Share on other sites More sharing options...
supra matt Posted February 11, 2008 Share Posted February 11, 2008 just pull the abs fuse's mate then you can rip it all out . Quote Link to comment Share on other sites More sharing options...
madmunky Posted February 11, 2008 Author Share Posted February 11, 2008 Sweet Anyone know about the air con? Can i just remove the pipes? Quote Link to comment Share on other sites More sharing options...
supra matt Posted February 11, 2008 Share Posted February 11, 2008 Sweet Anyone know about the air con? Can i just remove the pipes? If there is no gas in the system then yes you can remove the lot Pump ,rad , and all pipe work. That's a huge weight saving too Quote Link to comment Share on other sites More sharing options...
