Marco79 Posted February 9, 2008 Share Posted February 9, 2008 Just got a set of powder coated covers through and going to swop them over but does the cover hold the cams in place at all? just i know that in some cars the cover holds the cams in place and everything just springs out of place when you remove the cover lol . . . nearly forgot its a 94 n/a if that makes any difference Link to comment Share on other sites More sharing options...
Dazzi Posted February 9, 2008 Share Posted February 9, 2008 the cover comes off with an allen key (can't remember the size). Its safe to take off, nothin will break on you edit: you mean the rocker cover or the cam belt/spark plug cover? Link to comment Share on other sites More sharing options...
absz Posted February 9, 2008 Share Posted February 9, 2008 Just got a set of powder coated covers through and going to swop them over but does the cover hold the cams in place at all? just i know that in some cars the cover holds the cams in place and everything just springs out of place when you remove the cover lol . . . nearly forgot its a 94 n/a if that makes any difference i have never come across any car/engine were the cover holds the cams together, so i'm sure you should be ok;) Link to comment Share on other sites More sharing options...
RobSheffield Posted February 9, 2008 Share Posted February 9, 2008 Its a cam cover, just to help ya out in future Link to comment Share on other sites More sharing options...
Marco79 Posted February 9, 2008 Author Share Posted February 9, 2008 lol cheers for the help i just had to check as i have worked on cars before where just removing the cam cover ( ) has had the cams spring out and required re-timing. Not having done a 2jz before i thought it better to ask first Link to comment Share on other sites More sharing options...
and1c Posted February 10, 2008 Share Posted February 10, 2008 lol cheers for the help i just had to check as i have worked on cars before where just removing the cam cover ( ) has had the cams spring out and required re-timing. Not having done a 2jz before i thought it better to ask first Wow. Cam cover holding the cams in eh? Sounds a bit of a weird engine that one Link to comment Share on other sites More sharing options...
Marco79 Posted February 10, 2008 Author Share Posted February 10, 2008 tell me about it all hell broke lose nearly ducked for cover when things started moving lol Only had it the once think it could be a renault thing the french always like to spice things up a little Never had it since but wanted to double check just in case thanks for the help guys Link to comment Share on other sites More sharing options...
Rob Posted February 10, 2008 Share Posted February 10, 2008 I didn't think plastic could be powder coated. Let's see some piccies then, sounds nice. Link to comment Share on other sites More sharing options...
kieren1234 Posted February 10, 2008 Share Posted February 10, 2008 I didn't think plastic could be powder coated. Let's see some piccies then, sounds nice. The cam covers are aluminium, he doesnt mean the platic parts. Link to comment Share on other sites More sharing options...
Rob Posted February 11, 2008 Share Posted February 11, 2008 On the NA, you can barely see the cam covers. The plastic covers it, as does the throttle assembly. Link to comment Share on other sites More sharing options...
