chrisda Posted January 18, 2005 Share Posted January 18, 2005 Hi there,, I have a jap spec car with jap spec cats... Can I use the euros cats?.. The problem is with the Sub heated Oxygen sensor.. The sensor are on the 2nd cat on the euro and on the 1st on the jap.. Can I change that? Anyone? Kind regards Chris Bir Link to comment Share on other sites More sharing options...
Ian C Posted January 19, 2005 Share Posted January 19, 2005 You haven't got a sub heated oxygen sensor on a j-spec. There is a CAT temperature sensor though, which doesn't need to be plumbed into anything anyway. If you need a downpipe with a CAT on it I've got three spare -Ian Link to comment Share on other sites More sharing options...
penguin Posted January 19, 2005 Share Posted January 19, 2005 Hi Ian, Is that a downpipe and cat suitable for a jspec twinturbo (auto)?? would i need to have a restrictor ring aswell? (sorry to sound like a newbie....... but er..... ) Link to comment Share on other sites More sharing options...
Ian C Posted January 19, 2005 Share Posted January 19, 2005 It's a stock downpipe off a j-sepc twin turbo so it'll fit You shouldn't need a restrictor ring if you put a CAT in but why would anyone want CATs in?! -Ian Link to comment Share on other sites More sharing options...
penguin Posted January 19, 2005 Share Posted January 19, 2005 lol, very tru, i have no idea about decatting, i have been told its not a standard exhaust, and that only one cat is present, what would u suggest i do? ... Link to comment Share on other sites More sharing options...
Ian C Posted January 19, 2005 Share Posted January 19, 2005 Get rid of the other cat of course -Ian Link to comment Share on other sites More sharing options...
chrisda Posted January 20, 2005 Author Share Posted January 20, 2005 You haven't got a sub heated oxygen sensor on a j-spec. There is a CAT temperature sensor though, which doesn't need to be plumbed into anything anyway. If you need a downpipe with a CAT on it I've got three spare -Ian So if I have a euro catback(2nd cat) then I can just plugg the hole for the sub heating and maybe it should work then and get all exhaust values right.. Let me hear from u.. Regards chris Link to comment Share on other sites More sharing options...
Ian C Posted January 20, 2005 Share Posted January 20, 2005 OK, to clarify: All MkIVs have a main oxygen sensor in the turbo downpipe. If you decat the first cat, it's this downpipe that gets replaced and the decat pipe will have a boss in it for your stock oxygen sensor. If you have a UK spec, euro spec, or US spec you will have a second oxygen sensor. You will need to keep this in the exhaust stream so you'll need a 2nd cat decat exhaust that has a boss on it for this second oxygen sensor. If you have a jap spec MkIV you won't have a second oxygen sensor so no boss is required on your 2nd decat pipe. You will have a cat temperature probe though, which is a 3" long solid metal probe, looks nothing like an O2 sensor. This needs to be connected still, but doesn't need to be plumbed into the exhaust system, so simply tie tag it out of the way somewhere under the car. Double decatting a J-spec usually results in boost creep as the stock wastegate arrangement isn't beefy enough to bypass enough gas to control boost levels, so you'll need a restrictor ring in the exhaust system which limits boost to safer levels - nothing much past 1.2bar is generally recommended for stock J-spec turbos. Hope this helps -Ian Link to comment Share on other sites More sharing options...
chrisda Posted January 20, 2005 Author Share Posted January 20, 2005 OK, to clarify: All MkIVs have a main oxygen sensor in the turbo downpipe. If you decat the first cat, it's this downpipe that gets replaced and the decat pipe will have a boss in it for your stock oxygen sensor. If you have a UK spec, euro spec, or US spec you will have a second oxygen sensor. You will need to keep this in the exhaust stream so you'll need a 2nd cat decat exhaust that has a boss on it for this second oxygen sensor. If you have a jap spec MkIV you won't have a second oxygen sensor so no boss is required on your 2nd decat pipe. You will have a cat temperature probe though, which is a 3" long solid metal probe, looks nothing like an O2 sensor. This needs to be connected still, but doesn't need to be plumbed into the exhaust system, so simply tie tag it out of the way somewhere under the car. Double decatting a J-spec usually results in boost creep as the stock wastegate arrangement isn't beefy enough to bypass enough gas to control boost levels, so you'll need a restrictor ring in the exhaust system which limits boost to safer levels - nothing much past 1.2bar is generally recommended for stock J-spec turbos. Hope this helps -Ian Hi there Ian.... I I have a japspec... I have bought a original exhaust from a eurospec, I get it very sheap.. I just gonna have the exhaust to the mop as u call it in uk I think.. I front cat is still there on my var so I just need the second. And there is a snsor or something like that on that one. So the question is if I just can plug the hole on the euro cat that fits on the back? then it will work? Regards Chris Link to comment Share on other sites More sharing options...
Ian C Posted January 20, 2005 Share Posted January 20, 2005 Hi there Ian.... I I have a japspec... I have bought a original exhaust from a eurospec, I get it very sheap.. I just gonna have the exhaust to the mop as u call it in uk I think.. I front cat is still there on my var so I just need the second. And there is a snsor or something like that on that one. So the question is if I just can plug the hole on the euro cat that fits on the back? then it will work? Regards Chris So you have one oxygen sensor but a centre exhaust section that has a boss for a second oxygen sensor, yes? If that is the case you just need to weld it up or screw in a blanking plug. I have no idea what you are referring to as a 'mop', sorry -Ian Link to comment Share on other sites More sharing options...
Alex Posted January 20, 2005 Share Posted January 20, 2005 Chris, Can we have photo's of the parts please? I think you are saying you've got a sensor hole in your second decat pipe but that decat pipe is for a UK/Euro. If so it should fit. If in that pipe there is a hold for a sensor, it is for an optional Wide Band O2 sensor - seal the hole with an M18 bolt and do not worry about it. A Wide Band O2 is used by tuners to check the air/fuel ratio. Hope that helps EDIT - (Or of course Ian could write the same thing first) Link to comment Share on other sites More sharing options...
