GSC cams
xxcat
What do you guys think about the GSC Power-Divisions S1 Camshafts? In comparision with HKS.
GSC Stage 1
According to supraforums:
Conclusion: In conclusion, the GSC cams over the 264 HKS cams make 40-50 MORE rwhp at the same boost while sacrificing 50-100 rpm of spool. The curve with the GSC cams is MUCH MUCH MUCH better, holding power to redline at all power levels up to about 950 rwhp. At the end of the day, these cams are the best thing since sliced bread. Power pick-up over the HKS 264 cam and the ability to fit the head with simple shimming of the valves. There is no need to do any cutting or burring of the head, they pop right in. From my perspective, I highly recommend these cams.
GSC Stage 1
Who on Supraforums came to that conclusion, was he by chance trying to sell them? Did they do back to back testing of both? Don't believe everything you read :)
The cams do have a different profile and higher lift compared to the HKS cams, so on a big turbo may have some top end benefit.
From the blurb above and the one of the website I'd say they sound too good to be true. The website also talks about needing a 'valve spring upgrade' after previously saying easy install with just reshimming.... :search:
Would like to see back to back comparison testing with some of the other aftermarket cam sets available.
Cheers,
Brian.
Who on Supraforums came to that conclusion, was he by chance trying to sell them? Did they do back to back testing of both?...
link
They are also a similar price to the HKS and JUN cams. I know which I would choose to use.
which and why? :)
which and why? :)
I personally use HKS cams in my own car, but would have no hesitation going with either JUN or HKS, as they are both thoroughly tried and tested in many engines.
The JUN cams give a little more lift compared the HKS, but are slightly more expensive.
Of course the springs need upgrading, it is due to the lift. It *should* be done with the HKS ones too IMHO.
GSC are a very well respected company who have done a lot with the Supra/2JZ platform. I would pick them over HKS cams every day of the week. Turbo engines like lift, HKS seem too focused on duration (hence the 280s, which have no more lift than their 272s, and make no more power).
  • 3 months later...
  • 4 weeks later...
Not nesessarily. If nothing else in the valvetrain is changing then the spring rate would only need increasing if the maximum valve acceleration was increasing. This may happen if the lift increases but the duration does not. Cams that lift higher but do so over a longer duration may not need stronger springs.
I'm not saying that any particular cam lifts or duration combinations do or don't require spring upgrades, but just clarifying that it doesn't automatically follow that higher lift = stronger spring :)
Going with the manufacturer's recommendation is a sensbile thing to do.
GSC has a Very good Reputation in the EVO world, infact you'll find more big power evo's running GSC S1's than HKS cams, and many people are upgrading from HKS to the new S1's on their cars.
I believe this is due to the fact that with a smaller duration say 264 vs 272 the 264 S1's have more of an aggressive lift than the hks 272 so gaining a lot more mid range power.
Edited by bondango (see edit history)
  • 4 weeks later...
Yeah, I heard that too, many Evos are running the GSC cams but they dont't seem to have been used that extensively in the supra scene.
Also, I believe the S1s are not 264s but 269s
Any more input would be appricated
Yeah, 269 is the measured duration for the S1. I know the s2's have been put up against the HKS 264's and came out on top. Though the test bed was a 1000hp supra, im still waiting on a test with results from Greg on GSC S1 cams vs hks 264's in a medium power engine.
Theres a thread on supraforums that is worth keeping an eye on.
Marty
